585,758 active members*
4,152 visitors online*
    Feb 2019
    Fanuc 180i Loop Counte
    M98 P0002 L10
    Has any system varible for paramater "L" except Macro B ?
    exp:
    M6T#100
    #100 = #100 + 1 >>>>>> omitted
    Feb 2011
    353
    Re: Fanuc 180i Loop Counte
    I am not sure what you are trying to do as a loop counter
    M98 P0002 L10-- this will run the program 0002 10times
    M6T#100
    #100 = #100 + 1 >>>>>> omitted ---what is it you want omitted?
    this would make the the tool number increase by 1 each time and index but you would need to start at a specific number or else it could start with any tool # and all tools will do the same tool paths
    if this is all the program and you are looking to index to the next tool 10 times this would work
    I would use the G65 Instead of the m98 because you can bring local variables into the sub program
    G65P0002A1L10(P=PROGRAM, A= STARTING TOOL #, L =NUMBER OF REPEATS)
    O0002
    M6T#1(THIS IS A)
    G4P2000(DWELL FOR 2 SEC.)
    #1=#1+1
    M30
    an other option is a while statement
    M98P0002
    O0002( The while statement will run 10 times)
    #100=1(STARTING TOOL)
    #101=10(ENDING TOOL)
    WHILE[#100LT#101]DO1
    M6T#100
    #100=#100+1
    END1
    Feb 2019
    As we know some system variables for purpose
    exp:
    Modal Information
    #4001 to #4130
    I'm looking for #???? for counter when I use M98, G66, G65....ect.
    #???? will automatically count by fanuc system except Local, Common variables
    Feb 2011
    353
    these may be for the parts counter
    #3901 = Parts Machined
    #3902 = parts required
    Feb 2019
    I take a shot from machine screen
    Sub program run one time, the number will -1 until 0
    It should be saved by a variable.
  1. FANUC 180i mb alarm 8 on main board
    By Nil27 in forum Fanuc
    Last Post: 12-27-2018, 10:39 PM
  2. Fanuc 180i/ New Ball screw
    By Gotemcity in forum Fanuc
    Last Post: 07-24-2015, 05:18 AM
  3. Replies: 10
    Last Post: 03-02-2013, 05:00 AM
  4. post processor fanuc 18i mb5 and fanuc 180i Ma
    By nickargas in forum PTC Pro/Manufacture
    Last Post: 02-27-2013, 11:54 AM
  5. G68 Rotation problem on Fanuc 180i
    By btdmfg in forum Fanuc
    Last Post: 12-05-2008, 01:58 AM
