585,927 active members*
4,005 visitors online*
    Mar 2014
    39
    Roland Pix3 3-D Touch Probe Scanner
    I have recently purchased a Roland Pix3 touch Probe Scanner. I know it is long since been discontinued, and probably goes back to
    Win 95. Any information regarding setting it up would be appreciated. I am assuming that it will only work with a 32 bit machine,
    luckily I do have one that I can run either Windows XP or Win 7 on, 32 bit. I have been told that the 9 pin serial hook-up presents problems,
    Please get back to me with any information that you have on this set-up. I can also be reached at [email protected].
    thank you,
    Witelite
    Apr 2004
    5737
    Re: Roland Pix3 3-D Touch Probe Scanner
    Have you tried hooking it up yet? If so, what was the problem?
    Andrew Werby
    Website
    Mar 2014
    39
    Yes, I connected it from my Scanner to my 9 pin serial port on my i-5 Desktop, installed Dr Picza v 2.7. I first went into the controller to set the pitch to .006 for both X and Y axes. A problem occurs when I go to set the Z Bottom.
    I get the following message for all 4 ports. "Com 1 not ready. Please verify that the port is valid or is not in use by another application". I change the port number in File\ Preferences.
    Thanks for your response,
    Witelite
    Apr 2004
    5737
    Try com 2.
    Andrew Werby
    Website
    Mar 2014
    39
    I get the same message for all four ports.
  1. Need help with a Roland Picza Pix 30 3-D Scanner
    By calabash in forum 3D Printing / Scanning Software and Hardware
    Last Post: 03-17-2018, 02:39 PM
  2. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  3. Touch probe or 3d scanner/ photo based
    By zonker in forum Digitizing and Laser Digitizing
    Last Post: 09-07-2010, 08:24 PM
  4. Roland PIX-3 3D Touch Probe Digitizer
    By chich2 in forum Digitizing and Laser Digitizing
    Last Post: 09-04-2008, 12:59 PM
  5. Has anyone used a Roland 3D scanner
    By buscht in forum Digitizing and Laser Digitizing
    Last Post: 04-10-2004, 08:57 PM
