584,830 active members*
5,630 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Tool Path Starting Point
    Apr 2016
    59
    Several years back, I noticed a thread that suggested the idea of being able to select a point where madCAM would begin a toolpath operation.
    Was this ever implemented or is there another way to do this?
    Best regards,
    Bruce
    Mar 2004
    1661
    Re: Tool Path Starting Point
    Can't recall it was made, but I like the idea though.
    Oct 2009
    96
    Bcavender,
    "Select Start Points"
    This is where you select it in 3/4/5 versions see pic below.
    I have not used it.
    Joakim should be able to tell you how it works.
    Regards,
    Mauri.
    Apr 2016
    59
    Quote Originally Posted by Mauri R View Post
    Bcavender,
    I have not used it.
    Regards,
    Mauri.
    Mauri,
    Thank you!!!
    I had not noticed that selection in the Stock and Regions menu.
    I defined a point, selected it with the command you suggested (thinking it might work like creating a region) and then immediately generated a toolpath for that pocket, but that point was somehow not associated with the next created tool path.
    Maybe I am missing some other step or it's not fully implemented yet. The HELP section in my package doesn't show that command yet.
    I think I am running the latest version. Haven't seen an update popup in a while.
    Bruce
    Apr 2016
    59
    I am sending the question to Joakim. Will report back what I find.
    Tnx!
    Bruce
  1. Set starting point for tool?
    By radboi22 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-06-2016, 04:02 AM
  2. entry point for tool path
    By lovely123 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-21-2015, 01:34 PM
  3. Need help starting point and ending point wont contact
    By miketola in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2014, 08:04 AM
  4. SC 2010 Tool path start point
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-27-2013, 03:18 AM
  5. point machining tool path pattern
    By 60rock in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-20-2012, 08:20 PM
