585,974 active members*
4,523 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Arduino based CNC controller for engraver - how to wire up a motor and laser
    Jun 2008
    91
    Guys, hopefully this is in the right forum, it's more how to physically connect these items rather than anything to do specifically with engraving.
    I have an R3 Uno Arduino clone plus the protoneer v3 CNC shield, and despite numerous searches I'm none the wiser as to where I sould be connecting the output for the spindle motor, or a laser when I finally get one. The current engraver setup has a Woodpecker board that has no motor speed control, just on off control, but the output speed is too low to use with small diameter tools, and can't be changed. I'm hoping that an 'upgrade' to the arduino based board will allow me to control the spindle speed and latterly the Laser power through the software.
    Neither will be high power rated (2.5w Laser) as I am not intending to do any heavy work. So, which pins are the ones I have to connect to, and what collateral hardware will I require in order to get this connected up?
    Cheers
    Les
    Mar 2015
    409
    Re: Arduino based CNC controller for engraver - how to wire up a motor and laser
    GRBL has a very good wiki. Have a look at https://github.com/gnea/grbl/wiki/Connecting-Grbl to get started. I am not familiar with your protoneer v3 CNC shield. You maybe have to the shields documentation!
    Jun 2008
    91
    Quote Originally Posted by hfjbuis View Post
    Thanks, but as with the other sites I have looked on, it tells you the arduino pinout data, but fails to explain where you connect the devices to the CNC shield. All the sites explain well how to install the stepper motor drivers, end stop switches and jog switches, but somehow fail to mention the spindle motor or laser pin arrangements
    For instance do I need a separate motor controller board? Do I output direct to the motor? For the laser I assume there will be a control board.
    Cheers
    Les
    Mar 2015
    409
    Well the GRBL Wiki is made for GRBL, not the hundreds of available shields. Your shield documentation should show how to connect. Post the connection diagram of your shield and I will have a look.
  1. CNC Indexer (Arduino based)
    By WmCnc in forum Open Source Controller Boards
    Last Post: 10-22-2022, 09:41 PM
  2. Anilam 5300MK HMI PC-based controller conversion to Desktop PC-based controller
    By woudie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2017, 05:13 PM
  3. DIY Controller laser Arduino Vs Controller general (mach3)
    By jorgeluis in forum Laser Hardware
    Last Post: 09-03-2015, 12:22 AM
  4. Replies: 6
    Last Post: 05-09-2006, 03:52 PM
