585,877 active members*
3,461 visitors online*
    Feb 2019
    X-axis jumping rack and pinion
    Hi.
    I've am building a CNC router. For some reason, my motor keeps jumping off of the rack. The machine will drag the gantry just fine, but it doesn't like to push it... Any ideas?
    Sean
    Attachments Pending Approval Attachments Pending Approval
    Apr 2005
    253
    Re: X-axis jumping rack and pinion
    I think you have the pivot point too high, can you move your pivot/mounting point down so the motor assembly is more horizontal with the rack?
    I'll get it finished sometime after I start it.....
    Sep 2005
    1740
    Pictures you could actually see would help.
  1. Ballscrews or rack and pinion? What module of rack and pinion is the best?
    By masinecc in forum DIY CNC Router Table Machines
    Last Post: 04-13-2015, 06:04 PM
  2. Rack and pinion x axis
    By thunderdork in forum DIY CNC Router Table Machines
    Last Post: 07-28-2013, 12:21 PM
  3. x axis rack and pinion and linear track help
    By ikhan42 in forum Linear and Rotary Motion
    Last Post: 06-08-2011, 04:45 AM
  4. Modified CRP100-00 with center rack and pinion x-axis
    By cslarson in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 09-06-2010, 01:34 PM
  5. Rack and Pinion for x, y axis question ???
    By zeoncomp in forum Waterjet General Topics
    Last Post: 09-22-2007, 03:19 PM
