Q&D speed control
I'm working on a var feed system for a something like a planer. It's more elaborate than that, other activities involved. Nonetheless, what I would like to do is monitor the amp draw on the machine. Then use that to control the feed speed. i.e. as the load gets higher the amp draw will raise and, via my imaginary board, will decrease the speed. What I have so far is a Minarik mm23000 drive running a 90vdc motor. The drive has, among other things, a speed pot. What I imagine is a board, similar to a breakout board, that will monitor the amperage and output something that that would parallel or simulate the pot. I contacted Minarik and basically was told it can't be done. Since I already have a working setup I rather not convert to a VFD since I don't think it would be much different that what I have anyway.
Thanks for any thoughts or ideas.
Nothing is impossible. It's just a question of practicality.
