585,906 active members*
3,714 visitors online*
    Mar 2018
    6
    Question Wiring a rotary encoder
    hi
    I'm building a rotary encoder using optical sensors for spindle speed feedback to linux CNC but need help with wiring it and resistors needed. I am going to have 50 slots and channels a b z. My spindle tops out at 2500 so the max frequency would be (50 x 4 x 2500)/60 = 8.33khz (if i'm correct).
    1 The MX3660 says the inputs are 12v sourcing but the output from the photo sensors is 5v. Would this matter? if so is there a way to amplify the signal? (as an aside my home switches work ok with it and they read -10.5 to 10.5v when triggered.
    2: if it does matter could I run the emmiter side on 5v then have the collector side take a wire direct from the parrallel port @3v and then run it straight to the ground of the parallel port? Linux cnc has a function where you can measure pin signals and if I ground out the correct pin it switches between true and false. I wondered if there are reasons why this couldn't be done?
    Please help with advice as i'm fairly stuck.
    Jools
    Dec 2003
    24221
    Re: Wiring a rotary encoder
    Why re-invent the wheel, if using photo devices anything over around 100p.rev requires a Moiré effect reading head.
    Also if just measuring RPM, you don't need a quadrature encoder unless you have positioning and direction in mind.
    .What do you intend doing with the signal?
    Also you need a system that can read the sensor without interrupt in a constant manner.
    Al.
    Albert E.
    Mar 2018
    6
    Whats this? The optical sensor is of the interupptor style sensing though a slotted disk?
    rigid tapping
    What kind of system would this be? do you have any diagrams or links that could instruct me?
    Al.
    Jools
    Dec 2003
    24221
    Rigid tapping usually requires a higher resolution that this.
    I don't use Linux.
    Max.
    Albert E.
  1. ROTARY ENCODER
    By Shreimer in forum Bridgeport / Hardinge Mills
    Last Post: 05-18-2013, 03:53 PM
  2. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  3. rotary encoder erm 280
    By brainlessme in forum Servo Motors / Drives
    Last Post: 01-11-2012, 10:40 AM
  4. Rotary encoder wiring help please!
    By williamsmotower in forum Servo Motors / Drives
    Last Post: 03-21-2011, 06:40 PM
  5. rotary encoder help
    By anslee in forum Linear and Rotary Motion
    Last Post: 11-18-2008, 02:24 AM
