586,013 active members*
4,137 visitors online*
    Jan 2012
    163
    good tool holders to get ?
    what are some good tool holders to get for pm25mv? should i use collets to hold endmills or get endmill holders?
    1943
    Re: good tool holders to get ?
    Assuming you are talking about R8 holders, I personally prefer end mill holders rather than collets.
    Someone will come along and say that you have to get Tormach TTS style holders, and there is a bit of benefit with tool changing, but I haven't had any problems using the good old R8 end mill holders.
    Jan 2018
    1516
    Quote Originally Posted by 109jb View Post
    I have both direct collets and ER32 holders.
    Prefer the holders for ease of use but it's easier to get near 0 run-out with the direct ones.
    So both have their benefits.
    For good results get your holders from a proper tooling/engineer retailer. Don't go cheap Chinese on the holders/collet sets.
    I use a wide variety of set screw and ER holders. I've had very good luck with cheap set screw type holders most of them having very little runout, though a few have been questionable. With ER holders cheaper can definitely get you in trouble, but I like ER25 and ER32. I have one of each. They add a lot of flexibility to your tool holdiing library. I think I have 30 or so set screw type and two ER25 chucks and two ER32 chucks but only one set of collets for each.
  1. Replies: 3
    Last Post: 04-30-2020, 10:24 PM
  2. Glacern vises and tool holders how good are they
    By lkenney in forum Haas Mills
    Last Post: 09-14-2018, 07:33 PM
  3. Good source for mid grade tool holders - CAT 50
    By Rotax91 in forum Haas Mills
    Last Post: 01-26-2016, 07:14 PM
  4. Shars R8 solid tool holders, are they any good?
    By fusion_crank in forum MetalWork Discussion
    Last Post: 12-05-2011, 09:11 PM
