585,996 active members*
4,193 visitors online*
Page 2 of 3 123
Results 21 to 40 of 45
  1. #21
    Feb 2019
    91
    Re: First Cnc Build With extrusion
    some parts already arrive need to recheck everything first before cut all the plate,and checking alu extrusion, looks like they cut the size really perfect within 0.1mm.
    and i got vacuum table for size 300*400 around 400usd that i can use air compressor with it no need vacuum
  2. #22
    Feb 2019
    91
    got this server case with high flow fan for 10 dollar to fit my controller
  3. #23
    Feb 2019
    91
    today assembling Y axis rail and allign it together to 0.0001'' and i put some sand in static part(base) still thinking should iput something in moving gantry such as expanding foam to reduce the vibration
  4. #24
    Jul 2018
    6337
    Hi Team - Why solve a perceived problem before its a problem? There's lots of routers built out of extrusions and they have no vibration issues so only solve problems that exist.
    Plus why have your columns dog legged? The loadpath is from the top to the bearings so this is where material should be. To reduce weight put a hole in it but its best leave edges straight? Peter
  5. #25
    Feb 2019
    91
    thanks for suggestion yeah i already fix it, the problem is i already order extrusion that length and i have no idea where to cut it now to get to nice tolerance compare to factory cut
  6. #26
    Feb 2019
    91
    today cutting front plate for motor mount work perfectly for my servo
  7. #27
    Feb 2019
    91
    already cut my gantry plate by following your suggestion take 6 hours to finish by using workbee cnc pretty conservative with it
  8. #28
    Jul 2018
    6337
    Hi Team - Slow and steady wins most races. Peter
  9. #29
    Feb 2019
    91
    done assembly my gantry,all measurement is accurate to 0.005-0.01mm pretty nervous since its my first time design and making own cnc
    and just curious will my 2x 400watt servo can handle my gantry that i calculate around 100kg-120kg total with spindle
  10. #30
    Feb 2019
    91
    making my own nut holder and its pretty accurate and no binding when moving axis and today also installing my Delta 400w servo with brake for z axis im not satisfied with the mount but yeah will improve and integrate with the axis holder together when finish this since i already dissamble all part from old machine
  11. #31
    Feb 2019
    91
    custom spindle holder for easy tramming
    Attached Thumbnails Attached Thumbnails photo_2019-04-24_21-30-21.jpg   photo_2019-04-24_21-30-20.jpg
  12. #32
    Feb 2019
    91
    done for now
  13. #33
    Feb 2019
    91
    having 2 choice right now regarding belting.. should i go 1:2 for 300 ipm max or 1:1.5 for 400 ipm
  14. #34
    Jul 2018
    6337
    Hi Team - that's a serious chunk of aluminium and bolts. Keep at it. Peter
  15. #35
    Feb 2019
    91
    done all wiring tomorrow can start calibrate and im setting Y axis to gantry mode for servo drive to be on same setting since its dual motor axis
  16. #36
    ericks Guest
    Quote Originally Posted by teamloks1 View Post
    Wow....you almost there! well done
  17. #37
    Feb 2019
    91
    Quote Originally Posted by ericks View Post
    yeah just need to setting some pin and servo that take time i think haha
  18. #38
    Feb 2019
    91
    everything work well for now i set 400ipm to all axis and 1000 for acc i can set higher but got wobble for my table since i use table with roller
  19. #39
    Feb 2019
    91
    latest picture for my build the atc spindle is used i bought for 800 usd which got good tolerance around 0.004mm by testing using 300mm bar and the weigh tof z axis around 30kg which i use with 400watt servo with 1:2 ratio
    Attached Thumbnails Attached Thumbnails photo_2019-06-03_19-49-30.jpg   photo_2019-06-03_19-49-29.jpg   photo_2019-06-03_19-49-28.jpg   photo_2019-06-03_19-49-28 (2).jpg
    photo_2019-06-03_19-49-27.jpg   photo_2019-06-03_19-49-26.jpg   photo_2019-06-03_19-49-25.jpg
  20. #40
    Mar 2018
    70
    That looks pretty good.
Page 2 of 3 123
  1. 4x9 CNC Wood/Steel/Extrusion build
    By javabugz in forum CNC Wood Router Project Log
    Last Post: 01-19-2021, 03:14 AM
  2. Aluminium-/Extrusion CNC Build
    By millhouse_ in forum DIY CNC Router Table Machines
    Last Post: 11-08-2018, 07:54 PM
  3. 80/20 extrusion router build
    By jfong in forum CNC Wood Router Project Log
    Last Post: 09-12-2018, 05:10 PM
  4. 1st build, Aluminium extrusion based
    By andtfoot in forum CNC Wood Router Project Log
    Last Post: 11-20-2015, 03:46 PM
  5. What extrusion should I use to build a cnc table?
    By EKFER in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 05-16-2012, 04:55 PM
