586,005 active members*
5,078 visitors online*
Results 1 to 9 of 9
    Feb 2019
    CNC Lathe G-code for cutting radius
    Hi, guys im trying to code a 2mm radius cut into stainless steel on our Okuma LB15 CNC lathe, however, im getting the error, alarm B data word arc cal. 3
    can anyone see what is wrong with the code?
    G00 X300Z200
    T0303M03M08M42S2005G97
    G00 X20Z50
    G00 Z2
    G01 Z-8F0.1
    G01 X28
    G03 X30Z-10K-2
    G01 Z-14
    G00 Z100X50
    G00 X300Z200
    MO2
    Re: CNC Lathe G-code for cutting radius
    Hi Kyle,
    Your G03 line looks okay, though for doing a 90° arc it would be easier to use R2.0 instead of K-2.0, not that it is wrong.
    The issue is the line before "G01 X28.0" as the X works in diameter on a lathe, so to produce a 2mm radius you move 2mm in Z but 4mm in X, so you would need to start at X26.0.
    Dec 2008
    3109
    doubled up
    Jun 2015
    4154
    hy kyle replace K-2 with L2 and it will work; check attached : there is no way to get a r2 using k-2
    if you wish, check also this okuma forum, it is pretty good : https://www.cnczone.com/forums/okuma/
    kindly
    ps : try this shorter version
    Code:
    G00 X300Z200
    T0303G97S2000M03M08M42G00X20Z2F0.1G95(M63)
    G01 Z-8
        X28
    G03 X30Z-10
    G01 Z-14
        X31Z-13.5
    G00 X300Z200M05M09(M63)
    Feb 2011
    353
    The LB15 that i have worked on also has chamfering and corner rounding
    corner rounding would be
    G00 X300Z200
    G00 X20Z50
    G00 Z2
    G01 Z-8F0.1
    G76G01X30L-2.
    G01 Z-14
    G00 Z100X50
    G00 X300Z200
    also there is no cutter comp set and if a 2mm radius is wanted the 2mm would have to be compensated for by the tool nose radius
    Jun 2015
    4154
    hy rcs initial shape may not be suitable for g76L±2, because difference between diameters is 30-28=2, thus 1per radius, so :
    ... there will be a nice 'fit' for a circle with radius 2 ( >1 ); aesthetically speaking, chamfer radius should be <=1
    ... because the circle radius is greater then the face ( 2>1 ), then there will be the case of 'chamfering' 2 paralel lines
    attached is the shape; it can be seen that using a circle with rad 2 is overshooting with 0.017 above the o30
    to fix that code :
    ... i would recomand using r1 instead of r2
    ... like you said, activating comp / kindly
    Dec 2008
    3109
    This post was started back in March 2019
    the OP has probably worked it out
    so kitty... stop beating a dead horse
    .... there is no one at home to test your code.
    Feb 2011
    353
    Quote Originally Posted by deadlykitten View Post
    to fix that code :
    deadlykitten if you had looked at the post you would have found that the op program starts a x20 then goes to x28 in my version i had removed the line G1X28 so that the linear movement would be from 20mm to 30 mm with the 2mm corner radius
    Jun 2015
    4154
    hi rcs yes, i see now, but this would deliver a different part, without the o28
    well, is ok 2 show how g76 works, but like superman said, it's old stuff, and i didn't see that / kindly
