585,973 active members*
4,057 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Kollmorgen BDS4 Drive issue
    Dec 2015
    26
    My Arrow 500 has yet another problem.The machine has been in hibernation for the last 2 years. I had no issues with any of the drives when it was powered up then.
    I just went through changing the CMOS batteries and had Maver1k reflash the RT board. Everything is now up and running except my Y axis drive.
    Prior to having my batteries replaced I couldn't do much. One thing I did notice though was that every time I powered up the machine the 'control volts' and 'undervolts' LED was lit on the X and Z axis which is normal. The Y axis only had the 'control volts' lit. After the software loads and I push the power button again, all the drives have green LEDs indicating all is good. I can jog Z and X but Y does not move the table. When I proceed to the align process, the machine errors out at the Y movement. I then get the 44-44, and 44-45 alarm.
    I swapped the X and Y drives and the problem followed along with the drive. Any thoughts out there?? Thanks
    Oct 2011
    205
    Re: Kollmorgen BDS4 Drive issue
    send it to mike kilroy for repair
  1. VFS5 Kollmorgen drive
    By juniormachinist in forum Cincinnati CNC
    Last Post: 05-27-2022, 08:23 AM
  2. Replies: 8
    Last Post: 04-04-2021, 07:33 PM
  3. Model Kollmorgen BDS4
    By megaman26 in forum Cincinnati CNC
    Last Post: 12-27-2017, 08:41 PM
  4. Kollmorgen BDS4 206 23 possible failure
    By JFYM88 in forum Cincinnati CNC
    Last Post: 07-17-2015, 02:36 PM
  5. Kollmorgen Drive Repair
    By Stout in forum Stepper Motors / Drives
    Last Post: 11-14-2012, 08:09 PM
