584,861 active members*
4,843 visitors online*
Results 1 to 14 of 14
    Mar 2016
    20
    Mach3 + buttons for jogging issue
    Hi gays
    I have a problem to setup buttons with mach3. I tried two different PC's and both the same (LPT ports).
    I would like to use buttons for axis movement - X,Z. I set everything up but I have an issue, when I'am pressing left button - goes left but when I will take a finger of the button it is still going (seems like latching) won't stop - as long as hit limit switch or I will stop it by stop button. All buttons - directions the same.
    Video of that https://www.youtube.com/watch?v=CUXeZAUzniI
    All buttons set as OEM triggers
    x++ -307
    x-- -308
    z++ -311
    z-- -312
    I tried to fit up/down buttons for Z axis on my milling machine and the same. I press up goes UP and wont stop too, the same DOWN. I have usb smoothstepper there so it is not problem with lpt. May be wrong configuration of mach3 but I have no idea where??
    Thanks in advance and Best Regards Pav
    Re: Mach3 + buttons for jogging issue
    What version of Mach3 are you using?
    Mar 2016
    20
    3.043
    3.043.062? .066? There are lots of 3.043 versions.
    If you have an older version, try the latest one.
    There are lots of posts here and at other forums about runaway jogging, There seems to be a known issue with jogging with the Shift key. Not sure if yours is the same issue, though??
    Mar 2016
    20
    .066 I have but I used to have older version, same issue.
    I forgot to say, I have that runaway only when I am trying to use buttons, If I am using arrows on keyboard - all perfect.
    Jun 2010
    4252
    If the system works fine except for the buttons, an obvious first guess is that the buttons have a problem.
    Stick a voltmeter on the wires from a button and see what happens. Very slowly!
    Also check the power rail to the buttons.
    Cheers
    Roger
    Mar 2016
    20
    All checked, everything as should be. Button pressed - voltage, button released - no voltage. I have lathe and milling machine both made completely different way, one on smooth stepper, the other on LPT - both wrong.
    Jun 2010
    4252
    Um.
    My Mach3 (ESS) is set up with soft keys via USB port. That may not be relevant.
    Is your machine hardwired to those panel buttons for jogging? I can't help thinking that you have some sort of hardware fault or misconfig of pins if the keyboard works.
    Cheers
    Roger
    Mar 2016
    20
    I am using LPT breakout board. There is 5 inputs and I am using 4 of them to make machine move. I have no idea what I am doing wrong. 4 inputs 4 triggers, no idea???
    Mar 2016
    20
    Got another video of my mill this time. Happening only when I am using the buttons UP/DOWN - Z axis and only in continuous MODE. STEP mode seems to be ok. Best thing - keyboard keys for X,Y works perfect ???
    https://www.youtube.com/watch?v=682nMbih1as
    Looks like button sticks when pressed - but is not.
    Jun 2010
    4252
    The symptoms are so vague and your equipment is unknown to me. I doubt I can help. You REALLY need someone local and experienced to come on-site to debug the problem. I have no doubt it can be fixed, but probably not over the internet.
    Sorry
    Roger
    Mar 2016
    20
    Quote Originally Posted by RCaffin View Post
    Sorry
    Roger
    No problem thanks a lot.
    Mar 2016
    20
    Got it but I don't know how??????
    My HDD gone I had to reinstall windows mach3 etc. I installed .053 version and works, buttons for movement are working spot on (set them as JOG ++/-- on the bottom of input ports) but.....this time buttons for hotkeys doesn't. I set up everything like before no idea why. For example spindle ON - set as oem trigger, works if I press button on the screen but doesn't from external button. No idea. Is there anything what turn hotkeys on/off in mach3 settings???
    I installed linuxcnc as well and spindle ON/OFF works great, seems like I have issue with mach3
    Mar 2016
    20
    After lot of pain....job DONE.
    All works, all buttons done.
    When my hdd gone I reset BIOS.
    I had to setup again EPP and works.
    Thanks for help.
  1. SX3 Speed controller / buttons issue
    By williamssteve77 in forum X3/SX3/G0619/G0463
    Last Post: 03-08-2016, 06:36 PM
  2. Problems with Mach3 Jogging.
    By Ncrazyballa in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2012, 01:27 AM
  3. Jogging issue when I try to rapid
    By pimpbike in forum Mach Mill
    Last Post: 02-08-2012, 03:54 AM
  4. Jogging control problems with Mach3
    By steve-broad in forum Mach Software (ArtSoft software)
    Last Post: 01-23-2012, 12:47 AM
  5. Programming Mach3 by just jogging the axes manually
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2008, 03:06 AM
