585,741 active members*
5,183 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > My little Ibanez S470DXQM neck repair project
Results 1 to 6 of 6
    Mar 2014
    1131
    The neck was broken in the headstock. Luckily no wound on the rest of the neck but the frets were weared down due to long time play. I made a simple fret press for the new stainless steel jumbo frets. Then pressed down all the new frets to position. Then I dressed them.
    And I wanted to have the headstock with a new look.
    Mar 2014
    1131
    Re: My little Ibanez S470DXQM neck repair project
    I cut the logo from 1mm aluminium sheet with 1mm 3 flute end mill.
    Mar 2014
    1131
    Attached Thumbnails Attached Thumbnails IMG_20190303_011220_HDR.jpg   IMG_20190303_120310_HDR.jpg   IMG_20190303_121932_HDR.jpg
    Mar 2014
    1131
    Mar 2014
    1131
    Today I epoxied the surface of the headstock. Now I need to wait some days to get the epoxy fully hardened. Then I'll sand the rest of the neck and apply a clear satin finish.
    15362
    Quote Originally Posted by Azalin View Post
    Great work I have one that needs work also
    Mactec54
  1. Replies: 6
    Last Post: 03-25-2021, 10:01 AM
  2. Ibanez RG model
    By vangelismetheny in forum Musical Instrument Design and Construction
    Last Post: 05-04-2010, 11:56 AM
  3. Ibanez jem 77 solid body
    By rockerfx in forum Musical Instrument Design and Construction
    Last Post: 07-10-2008, 12:07 PM
  4. Ibanez Wizard-7 neck g code
    By irg7620 in forum Musical Instrument Design and Construction
    Last Post: 12-18-2006, 08:43 PM
  5. my IBANEZ JEM with JACKSON neck
    By ertu in forum Musical Instrument Design and Construction
    Last Post: 09-23-2006, 08:35 AM
