585,981 active members*
4,338 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Need help with 1996 BMC4020
    Mar 2019
    9
    The scale is off on my Y axis. 1.000" of indicator movement reads 1.085" on the machine. .100" reads .1085" so it's 8.5% off. What's up?
    Jun 2008
    1104
    Re: Need help with 1996 BMC4020
    Go ‘Auxiliary’ ‘enter’ 100 ‘enter’ then go to CNC config, Y axis and then look at the pages to find the ‘counts per revolution’ for Y and compare it to X.
    Mar 2019
    9
    Thanks, I tried it. both axis say 4000 counts per revolution and 12MM per turn. Also, the zero set point keeps changing for Y. I can set zero and move the table around then when I check it it will be off .030-to .070"
    Jun 2008
    1104
    Check the pulley is tight, the belt is ok and see if it comes back to 0.000 and has the little dot next to the Y on the position display. If it doesn’t, it is electrically miscounting.
    Mar 2019
    9
    I switched the x and y plugs under the honda board and the problem went to the x display and manual control. so you could say the problem stayed with the Y motor and encoder,etc.
  1. Replies: 0
    Last Post: 06-17-2015, 07:13 AM
  2. Hurco BMC4020 CAS Oil Lubricator problem
    By Shishkinnick in forum HURCO
    Last Post: 11-25-2014, 11:21 AM
  3. Hurco BMC4020 parts catalogue?
    Last Post: 11-11-2014, 07:01 AM
  4. BMC4020
    By MartinKelemen in forum HURCO
    Last Post: 11-24-2009, 10:22 PM
  5. HURCO BMC4020
    By JEMLEO43 in forum HURCO
    Last Post: 11-26-2007, 09:48 PM
