586,011 active members*
4,892 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Flow Water jet - Amplifier Faults and more..
    Mar 2019
    Hi all,
    I am currently having issues with the waterjet which has occurring over the year.
    The main issue is trying to send the machine head to the "machine home" for it's start up routine which follows with "A pause or shut down has been activated. Check Advanced - Diagnostic tool.. to determine the cause of the pause or shut down".
    After going on the " FlowSENSE Diagnostic" tool it shows up with;
    "Amplifier fault shut down"
    " X Axis Amplifier fault"
    " Y Axis Amplifier fault".
    Yet the amplifier's themselves are not showing any Fault codes..
    Any ideas?
    Jun 2010
    463
    Re: Flow Water jet - Amplifier Faults and more..
    Give me a call....I can help you ....
    MCP Services
    678-548-1483
    Maurice Phelps
    Mar 2019
    Quote Originally Posted by MCPservice View Post
    MCP Services
    678-548-1483
    Maurice Phelps
    Hi, sorry for the late reply.
    As we are in different time zones i won't be able to call you at a sensible time. Could you list your suggested solutions please?
    Many thanks,
    Jake
    Quote Originally Posted by Jakeyy View Post
    Hi all,
    Any ideas?
    I am currently having the very similar issue that you have had. Did you find a solution to this problem?
  1. Water flow sensor
    By Mcbride19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2019, 04:34 PM
  2. CW-5200 water chiller flow alarm but flow is fine
    By dogeatdog5 in forum For Sale Only
    Last Post: 03-12-2018, 11:32 PM
  3. Just bought a Flow Water Jet
    By wileybrett in forum Waterjet General Topics
    Last Post: 01-16-2017, 08:55 PM
  4. Recommended water flow.
    By Go-C in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2015, 06:05 PM
  5. Water won't flow
    By Pysiek in forum Spindles / VFD
    Last Post: 05-30-2015, 04:16 PM
