586,000 active members*
4,834 visitors online*
Results 1 to 9 of 9
    Jun 2015
    109
    Syntec 6mb controller issue
    Hi
    Looking for guidance from anyone who has experienced a similar problem with the Sytnec 6mb.
    We have had this issue twice now with the same machine, its an Omni 1325 ATC and we have 3 of them.
    The controller is not taking any input from the upper keyboard, to the right of the screen, this has gone from an intermittent fault a few days when restarting the machine would clear it.
    I am it my wits end with it.
    Any guidance would be appreciated.
    Sep 2012
    228
    Re: Syntec 6mb controller issue
    checking the connections on the back of the controller would be a must.. if not already done..
    Jun 2015
    109
    Done that.
    Had an electronics engineer look at it, he took the keyboard out and took it back to his workshop for testing. He came back a few hours later and said he could not find anything amiss and said he expected it to work when he reassembled it. He thought it might be some dirt. Sure enough he put it back and now it’s ok.
    Jun 2015
    109
    Hi
    Guess what!
    We have the same issue with our newest machine which is only a few months old.
    I am kind of wondering whether it could e a voltage fluctuation issue but really clutching at straws. It's another intermittent problem which can be temporarily solved by turning the machine off and waiting a while, but the "while" can be anything from 5 minutes to several hours. Again we have checked the connections and can't find anything so we are calling an engineer in to investigate.
    Jan 2007
    626
    I'm wondering if its temperature related?
    Jun 2015
    109
    The engineer took out the keyboard and basically looked at it, couldn’t find anything wrong with it and put it back. Believe or or not it’s been working since then.
    Bizarre!
    Mar 2018
    11
    When i was trying to install a new firmware onto our Syntec 6MB it was required to connect a USB keyboard at the front of the machine. So this might be a quick & dirty fix when there faults again. Not sure if it's feasible to use the specific controls (cycle start and such). But it's definitely a bit easier to edit g-code directly on the machine.
    Apr 2004
    475
    I can confirm that, at least with an EZ3 control, the upper keyboard can be disconnected and the lower panel still works.
    It works best when the syntec keyboard is disconnected rather than trying to run both.
    Ctrl seems to be the reset button, all other functions on my panel I can get to via the F keys under the screen (now the F1-F5 on the keyboard.....left arrow is each, right arrow is f10)
    My F5key was having issues.....this should solve it especially once I get used to the change.
    Sent from my motorola one using Tapatalk
    Apr 2004
    475
    Well,
    Posted too soon on that one.
    The keyboard works, but not with full / regular alphanumeric use....it works like the panel keyboard, which is to say a lot of keys are remapped.
    The lower left CTLR is reset,
    The right shift key is the same as the panel shift key (ie, for me, shift D gives the letter A).
    Letter U (for me, your milage may vary) is Monitor button,
    Leter I is POS button,
    Letter J is PRM button,
    Letter V is Alarm Button
    .....letter K does change something when in the program editing mode, a line on the top of the screen changes from input to graphical input I think in abbreviated form.
    Letters that also seem to be reserved (ie typing them in the program edit window do nothing obvious)
    A
    Q
    W
    C
    H
    - beside the numbers
    The number pad is not used for numbers, maybe arrows, I haven't experimented too much. For example, The - key on the number pad works as a - key whereas the one mentioned above is reserved.
    But, it does work if your factory keypad is messed up.
  1. Difference between Syntec 6MB controller and NK 300 Controller
    By hunnyk in forum Centroid CNC Control Products
    Last Post: 12-23-2017, 05:38 AM
  2. Syntec 6 controller
    By SCC in forum Chinese Machines
    Last Post: 05-26-2016, 05:34 AM
  3. Syntec Controller
    By easytech in forum Chinese Machines
    Last Post: 06-30-2015, 10:41 AM
