585,557 active members*
3,505 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > BODOR Laser > Bodor, RD works Metalcut autofocus problem
    Sep 2016
    7
    I have a bodor 150W Co2 Metal/non Metal machine.
    When Ctting metal the machine uses ruida Live focus system to track the metal surface.
    Problem,
    I can cut one shape/path but when moving to next shape/path the laser head raises between the cuts.
    Timing is wrong and it cuts the next path without focusing.
    Basically it is trying to focusing while already cutting resulting in the first bit of the path not cut.
    Anybody knows what settings to tweek in RD works or on ruida controller...
    Best regards
    Dec 2018
    21
    Re: Bodor, RD works Metalcut autofocus problem
    Hello ebure! Sorry about the problem. May I know your email or Whatsapp? Bodor online aftersale service is waiting for help you.
    Mar 2016
    9
    hello
    Have you been able to find solution to your problem. I have just acquired a mix co2 laser and my problem is it starts cutting cutting after about 2 cm from the starting point even though the laser is on.
    Would very much appreciate if you could share experience and settings for mixcut.
