585,917 active members*
3,444 visitors online*
Thread: Help
    Nov 2016
    9
    Help
    Hi you have the configuration file for laser rabbit 1290SE had a leetro 6515 card now mounts rdc6442g thanks
    Nov 2016
    9
    Re: Help
    Non c'è nessuno che possa aiutarmi
    grazie
    Apr 2006
    108
    Re: Help..
    C'è sempre qualcuno che può aiutare
    Vendor Settings password "rd8888"
    The easiest method is to set each parameter in the "vendor settings"
    X-axis step 7.9375 um
    Y-axis step 7.9375 um
    Z-axis step size should be near 0.25 um
    if you need special help, I can connect to your PC and step through the process.
    I loved my time when I lived in italy.
    Ray Scott
    Rabbit Laser USA
    Nov 2016
    9
    Re: Help
    Thank you very much Rayscott for making good I will surely bother you again thanks Regards Gennaro
