585,951 active members*
3,701 visitors online*
Results 1 to 6 of 6
    Feb 2019
    10
    V-Rail vs Linear Guide Rail
    I am trying to get comfortable with buying a used 4 year old PRO4848 with V-Rails and low hours vs a new PRO4848 with the new linear guide rails. Could I hear from those of you with V-Rails and are satisfied with their accuracy and rigidity? I have only read comments about how superior the linear guide rails are but the cost difference is significant to me, so just trying to understand if it's really worth spending the extra money. I haven't really seen anything negative about the V-Rails. I will be using the machine for inlays and furniture so would like as high accuracy as I can afford. Thanks!
    May 2013
    480
    Re: V-Rail vs Linear Guide Rail
    are the v rails and their roller bearings arranged properly or are they subject to slop in the bearings.
    and even if they are subject to slop in the bearings are the bearings doubled up and preloaded or are they just a V groove sleeve press fit on a bearing.
    I've seen people with V Rail machines upgrade them to linear bearings, if that tells you anything.
    Feb 2019
    10
    I don't think I know how to tell... is there an easy way to see that?
    Jan 2015
    194
    I bought my CNCRP Pro 5x10 machine before the linear bearings were out and while I was building my machine, the linear bearing machines were released. I ordered the upgrade immediately so never actually used the V-con rails; I sold the parts to another user here. So you could save money and buy the current machine safe that if you needed or when you went, you can order the upgrade and have an up to date machine. You can reach out to CNCRP now to get a quote for the upgrade so you’ll know what your full cost would be.
    Apr 2015
    130
    I had the exact same situation as David, so I've only used Linear Rails. With linear rails, the machines are very ridged and accurate. I did leave the v-con Z axis on mine.
  1. Linear Guide Rail Selection - sizing
    By wheeliecake in forum Linear and Rotary Motion
    Last Post: 03-07-2019, 12:10 AM
  2. Lengthening the K40 X-Axis linear guide rail
    By mgleason_3 in forum DIY CNC Router Table Machines
    Last Post: 09-27-2018, 09:44 PM
  3. Linear guide rail - Light Blue grease ?
    By jxdxwx in forum Linear and Rotary Motion
    Last Post: 06-23-2015, 06:42 PM
  4. Linear guide rail question
    By janz99 in forum Linear and Rotary Motion
    Last Post: 06-21-2015, 04:37 AM
  5. THK FBW/FBW2560R Linear Bearing Guide Slide Rail
    By BackyardWorkshop in forum DIY CNC Router Table Machines
    Last Post: 09-02-2010, 07:52 AM
