585,752 active members*
4,002 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Retrofit of an EMCO 120 CNC lathe
Page 1 of 4 123
Results 1 to 20 of 70
    Hello everyone,
    I would like to present my retrofitting project of an EMCO 120 CNC lathe with a modern controller and new servos.
    The lathe was bought in 2017 and it came from a high school. It was in good condition but the fact that it required three-phase power and had a vintage Emcotronic T1 controller (with the inherent risk of potential problems that could derive from its age) pushed me to take the decision to retrofit it and convert it to single-phase power.
    For the axes, I chose to use 750W AC servomotors and drivers from DELTA, model ASD-B2-0721-B, to replace the original 5-pole Berger Lahr stepper motors.
    The original spindle motor was a 400V DC motor with 3.5hp. To simplify its connection to the new controller, I decided to replace it with a three-phase motor (2.2kW ABB branded) controlled by a single-phase input VFD (DELTA VFD022E21A).
    The choice of the controller was a bit more difficult ... At the beginning I thought to use Mach 3 or Eding CNC but the fact that these systems are PC based didn't convince me. Therefore I decided to take the risk of buying a dedicated Chinese controller on Ebay. My choice fell on a Szghauto "brand" controller (model SZGH-CNC990TDb-2).
    Apparently, as with most products coming these days from China, there are many available controllers similar to this one in which only the brand changes (Szghauto, Newkye, Newker,...). From what I understand, they are all "inspired" by vintage Fanuc controllers. For the moment I am quite satisfied with it. The price was competitive when compared to the cost of a license Mach 3 or Eding CNC + computer + screen + cards, etc. The only problem was the documentation. The Chinglish was almost incomprehensible. I wasted a fair number of hours because of it...
    I will add the photos next...
    Re: Retrofit of an EMCO 120 CNC lathe
    The original EMCO 120 lathe
    Attachment 414498
    The Emcotronic T1 controller
    Attachment 414500
    The original electronics
    Attachment 414502
    Beginning of the disassembly (original headstock motor removed)
    Attachment 414504
    Original headstock motor
    Attachment 414506
    Attachment 414508
    Original 5-pole stepper motors
    Attachment 414510
    Disassembly of the lathe part
    Attachment 414512
    Cleaning the headstock
    Attachment 414514
    Attachment 414516
    Disassembly of the electrical cabinet
    Attachment 414518
    The new controller (customized by the manufacturer with the EMCO logo )
    Attachment 414520
    Attachment 414522
    Attachment 414524
    The 750W AC servo/driver from DELTA
    The new headstock motor from ABB
    To mount the new controller in the electrical cabinet, I ordered a 4mm thick laser cut steel sheet and attached it to the existing cabinet front cover
    Attachment 414530
    Attachment 414532
    Attachment 414534
    I also took advantage of my order to cut out the mounting plates for the new headstock motor, the servos, the limit switches and a back plate for the electrical cabinet
    Attachment 414536
    Attachment 414538
    Attachment 414540
    Attachment 414542
    Since the original headstock motor had a maximum speed of 6000 rpm and the new engine only had 2850 rpm, I had to increase the diameter of the driving pulley so as not to lose too much top speed. In the end, I managed to have a maximum spindle speed of 4250 rpm.
    Attachment 414544
    Oct 2004
    832
    Looking forward to seeing how you get on with the controller. I recently bought the CNC1000TDC from SZGHAuto. I have not had a chance to connect it all up yet as I am busy and need the lathe to do parts at the moment.
    Hopefully I will get a chance in a month or so.
    Quote Originally Posted by Hood View Post
    It seems to be the same controller with just a different form factor... The installation went quite smoothly. All the cables provided by SZGHAuto were correctly labeled so it was almost plug-n-play. The only "complicated" part was making the turret work with the controller. I had to install an arduino based PLC to convert the turret signals. The painful part was setting the parameters though. The manual they provided was almost incomprehensible and some of the parameters mentioned there didn't seem to apply to my specific model...
    What cam software you will run with this controller ? I think the postprocessor the same as fanuc ...
    I'm using Fusion360 with the standard Fanuc postprocessor. It only required a few minor tweaks to some canned cycles.
    The follow-up...
    I also had to change the headstock encoder. I chose an "omron" with a resolution of 1024 steps/rev (x4). Its support was machined in a small EMCO Compact 5 CNC lathe that I had at the time...
    Attachment 414632
    Attachment 414634
    Beginning of the wiring
    Attachment 414636
    Attachment 414638
    Attachment 414640
    Wiring finished
    Attachment 414642
    Attachment 414644
    Attachment 414648
    Attachment 414650
    And new vinyl decals (of course )
    Attachment 414652
    Attachment 414654
    Attachment 414656
    And here is the finished lathe on its new custom made bench
    Attachment 414658
    And doing its job...
    Attachment 414660
    Overall, I am quite satisfied with the end result. The controller takes standard G code (USB or RS-232) and is quite simple to use. The mechanical part of the lathe does not seem to have much wear neither. The backlash in the ball screws is less than 2um and I can easily work within 0.01mm on mild steel.
    The only annoyance I have is the lack of torque at low speed. I may need to reduce the belt pulley ratio and tweak the VFD settings to mitigate this.
    I hope someone finds this project useful :wave:
    Cheers!
    Quote Originally Posted by mukanico View Post
    This is not the best way to achieve the RPM required. Most certainly the motor can easily handle 120Hz, (check the MFG for max RPM it's probably 6kRPM.) By increasing motor pulley diameter you've reduced torque to the spindle. This will be troublesome if you work steel at 2" diameter.
    Correct setup would give full motor torque to 60Hz, and as Hz increased to 120, available torque would drop but full HP would be available. As small diameter parts need less torque this is acceptable. This is how most spindle motors are configured. For my Emco I chose an ABB 2.2kW, 4 pole motor and run it to 6000RPM. This essentially matches the original motor exactly.
    Oct 2004
    832
    I think the CNC1000 has a faster processor, more memory and more I/O but likely the software is the same.
    I have been messing around with the control at home and working out quite a lot of things. I too had issues with the toolchanger, not so much about converting signals but more the macro. The macro itself wasn't too bad if you only wanted to use the 8 tool positions with 8 offsets but as I made a VDI turret for my lathe I wanted to be able to use the full 99 possible offsets. That didn't seem to be an issue at first but then I soon realised that it was messing with the graphic view. I asked SZGH if there was a mod function in ther software but sadly there wasn't and they said basically I would just have to use 8 tool positions and 8 offsets or use the 8 positions with 99 offsets and put up with the graphics display showing incorrectly.
    Thankfully however I found a way to basically mimic modulo so now I can do as I presently do with Mach, and call for example T1515 and the turret will go to position 7 but use offset 15 and the graphics will display properly.
    You mentioned earlier that they sorted you with the Emco logo screen, did they just send a file or did they load that before you purchased? I was trying to do my own but couldn't seem to manage to overwrite the default one.
    I sent them the image file before they shipped the controller and they loaded it. However, recently I also bought from them a milling controller (SZGH?CNC1500MDb?4) for another retrofit I did (I may do a post about it in the future) but forgot to ask for the logo screen. They sent me the instructions to do it myself. I have added them below as they might be applicable to your controller.
    How to change logo?
    1.Prepare a logo picture
    (Format:BMP , Dimension: 800*600)to exchange original logo picture in U-Disk, or (The Best Way)modify in the logo picture on computer.ensure the dimension and format unchanged.
    2.Change No.1 parameter to disable in Password ,and change No.12 parameter(inner parameter ) in Other parameter to 8. (steps:Press”Parameter” ,Press “F7”,enter”Passed” ,No.1,”Is enable CNC Co.’s password? “,press “Enter” ,express”Please input CNC Co.’s password ,the password is “111111”, ”input “1” mean “not”(is disable); And Press “F5”-Other,enter other parameter ,change the No.12 inner parameter to 8)
    3.Restore the parameter(logo picture) into system.
    (Steps:insert U-disk,press “F6”,enter U-disk,press “F2”-Restore ,input parameter,”Please input Machine Co.’s password:666666,press “Enter”,express “Are you sure to input PLC,soft,parameter to CNC?”,Press “Enter”,Input successful ,Please reboot CNC! ,press enter,press “F6”to exit U-disk.)
    4.Reboot CNC ,the logo change is finished.
    5.After reboot, set No.12 parameter in Other parameter to 7.And set No.1 parameter in Password parameter to Enable.
    Sep 2005
    1195
    Oct 2004
    832
    Thanks, I was missing the 666666 password bit, I knew the 111111 one. Will give it a go when I get a chance.
    Oct 2004
    832
    Looks like I am about to embark on my journey to fit the SZGH control. Yesterday I was trying to use the lathe and it was doing lots of weird things, wouldn't jog so restarted then wouldn't home so restarted, spindle wouldn't turn on so restarted etc etc.
    I started pulling the control panel and electrical panel to bits, some I will reuse such as PLC, Servo drives and relays but most will not be used.
    This stage of a retrofit is always a scary sight.... Good luck with it!
    What lathe is it?
    Oct 2004
    832
    Ha ha it is not too bad as I have done quite a few and the lathe itself was my third retrofit and has had a few enhancements over the time I have had it.
    It is a Churchill Computurn 290 that I bought about 2006 and fitted Mach3 to it, originally via the parallel port then the USB Smoothstepper and latterly the Ethernet Smoothstepper.
    I have known the control was dying for quite a while so have been planning the refit although I was torn between the SZGH and a CSMIO/IP-A (I have that on the Chiron FZ12S and love it) but the CS-Lab new software is not lathe compatible yet and Mach 3 and CSMIO has some niggles for lathe and Mach4 is a non-starter for me so it came down to my only real choice was the SZGH.
    Nice!
    I never used Mach 3 or the other PC based controllers so I can't do a direct comparison. But both SZGH controllers I have (lathe and mill) have been performing flawlessly so far and, price-wise, I didn't find them much more expensive than the hardware required to do a proper PC based retrofit from scratch. It just takes a while to get use to some of the chinese translation choices ("redeem" meaning tool library, etc.).
    Feb 2018
    11
    Hi Mukanico,i have Emco Compact 6 CNC with old TM02 I want to replace whit SZGH CNC990TDb 2.Can you please email me so I can ask you a few things.I see you have a good experience whit this SZGH.
    Thanks in advance Andrej. email is: [email protected]
    Oct 2004
    832
    I have never really had issues with Mach3 and it runs my Chiron, Beaver Mill and Plasma very well indeed. The lathe side of Mach3 works pretty well but there are a few things it does not do, one is CSS and although threading can be an issue for some it has never been an issue for me. I could have gone down the route of just getting another Smoothstepper or even going back to the USB version as I have a few here, but I wanted to go more industrial and thus CSMIO or SZGH were the choices.
    Price wise the CSMIO itself would be about the same as the SZGH but then again if the SZGH goes up the spout then you have a complete control to get where if the computer goes on a PC based system then a motherboard or hard drive is cheap enough.
    The downside I see to the SZGH is the configurability , it does seem quite configurable but no where near as much as Mach is and one thing I will miss is the network ability, I will take bad having to transfer files via USB but that is not the end of the world if it performs as well as I hope it will. My friend is currently converting an Avon mill to an Adtech and I think that has network ability but as he doesn't transfer files via network I suppose I won't really know how well it works but it will be interesting to see how the Adtech performs.
    Yes, the terms are quite funny, Redeem as you mention but the couple that make me chuckle is something like Curry tool is ...... when it should be current tool and also the Huff button which I take to be Air blast.
    Having to transfer the files over a USB stick can indeed be a bit annoying after a while. I read that one could configure a Raspberry Pi Zero W to act as a network connected USB drive. I'm planning on giving it a try sometime soon.
    https://www.raspberrypi.org/magpi/pi...b-flash-drive/
Page 1 of 4 123
  1. Emco retrofit
    By Eatonbrayer in forum PlanetCNC
    Last Post: 01-17-2019, 03:42 PM
  2. Emco PC Mill 50 Retrofit.
    By propellanttech in forum EMCO Mills
    Last Post: 09-24-2018, 01:10 AM
  3. Emco Unimat lathe CNC retrofit
    By ZeroBacklash in forum Benchtop Machines
    Last Post: 09-03-2018, 03:04 PM
  4. Emco Compact 5 Retrofit
    By Daniel.y in forum EMCO Lathe
    Last Post: 01-14-2015, 12:53 AM
  5. EMCO CNC5 Retrofit...
    By oldslotgeek in forum Mini Lathe
    Last Post: 12-31-2007, 01:52 PM
