585,982 active members*
4,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Which stepper motor size for Taig Z-axis?
    May 2006
    309
    My Taig Z-axis stepper loses step if I set up the speed to more than 20 inch/min, so maybe I need a stronger motor. I use Gecko 540 as driver and need to know which size of stepper motor I can use in order to prevent this.
    Aug 2016
    37
    Re: Which stepper motor size for Taig Z-axis?
    I have zero issues with my 386in/oz from Automation Direct and also a G540 with UC300ETH. And I'm running a 1 HP motor, R8 spindle with power draw bar.
    Another thing to check is see if your Z gib is too tight.
    May 2006
    309
    Quote Originally Posted by ThreeDJ16 View Post
    What do you mean about z gib? Is that the nut around the lead screw, or the clamps on the sides of the slide? I recently tighten it up in order to avoid backlash, so it could be the reason for this issue.
    Aug 2016
    37
    Quote Originally Posted by jaru-eri View Post
    Actually you should see a screw on the top and bottom of the Z saddle (right hand side) and that has the brass gib in between them. Best thing to do is rapid it back and forth and watch for hang ups. SInce you have made some changes, it could have affected the gib. You turn the top and bottom screws to push the gib around making it tighter or more loose. Youtube has some vids on how to do it. Just search Taig Mill there and a guy from Taig has vids on doing all that stuff.
  1. Taig stepper motor problems
    By pbmwco in forum Stepper Motors / Drives
    Last Post: 05-17-2018, 09:22 PM
  2. Replies: 8
    Last Post: 08-14-2017, 10:29 AM
  3. Stepper motor for Taig CNC mill
    By bramlego in forum Taig Mills / Lathes
    Last Post: 01-21-2013, 04:50 AM
  4. HM 48 stepper motor size
    By xrayxray in forum Benchtop Machines
    Last Post: 04-14-2012, 05:50 AM
  5. What size stepper motor is needed for rotary axis?
    By Dale gribble in forum Stepper Motors / Drives
    Last Post: 10-12-2010, 12:52 PM
