585,987 active members*
4,378 visitors online*
    Dec 2005
    112
    Delta 50P tool change error
    I have a LVD Shape Delta turret punch on which Dynapath Delta 50P is installed. Machine is running ok except when we rotate the turret anti-clock wise then the locking shotpin does not operate and machine operation haults. I am not much familiar with the controller's inner setup. Is it a problem with the parameters or the tool change macro. How can I access them.
    Zafar
    Aug 2011
    121
    Re: Delta 50P tool change error
    Zafar,
    Has it ever operated correctly? If yes, then it is unlikely to be a parameter or macro issue.
    RT
  1. Dynapath Delta 10 Tool Change Question
    By Fighter in forum Dynapath
    Last Post: 05-15-2017, 10:30 PM
  2. M06 tool change error
    By lee-gib in forum Fanuc
    Last Post: 04-11-2016, 06:20 PM
  3. VF5 tool change error 134
    By mstorto in forum Haas Mills
    Last Post: 02-17-2016, 09:30 PM
  4. vmc 760/22 following error on tool change
    By laserh20 in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2010, 10:41 AM
  5. Tool change error
    By mattpatt in forum Fadal
    Last Post: 06-17-2010, 01:18 AM
