585,930 active members*
3,954 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > The secret to keeping your acrylic engravings clean.[emoji6][emoji41]
    I've been engraving\cutting key chains. Thousands of them in acrylic & I had to find a way fast way to eliminate the residue without damaging the product. I couldn't find the solution I desperately needed, so I had to figure it out for myself. I suddenly realized that a product I use as a solution to help my 3D prints stick to the bed is also the same solution I needed to keep plastic residue from sticking to my engraved acrylic products.
    If you 3D print, then you already know about this product.
    It's called Aqua Net hair spray.
    Spray it on your acrylic BEFORE engraving. Then just rinse it off with warm water and the residue goes right with it. Nothing could be more easy!
    TokinSpokane
    Custom Crafts
    Sent from my SM-G935F using Tapatalk
    Feb 2017
    7
    Re: The secret to keeping your acrylic engravings clean.
    hey thanks for the tip! My question is, is this specific to the brand aquaNet or any hair spray?
    Jan 2008
    940
    When I set up drug stores we would use Aqua net hair spray to keep the chalk line from rubbing off before we set the fixture. The reason was it was real cheap and you could get it about anywhere.
    Quote Originally Posted by pugz View Post
    It is specific to AquaNet.
  1. How are you keeping your Mill area clean?
    By zerodegreec in forum Benchtop Machines
    Last Post: 03-15-2019, 03:44 PM
  2. Keeping Coolant Clean?
    By donl517 in forum Fadal
    Last Post: 02-01-2010, 10:31 PM
  3. Showing off a bit-- Acrylic engravings
    By jacampb2 in forum Machine Created Art
    Last Post: 11-28-2009, 05:14 AM
  4. keeping rails clean
    By HMD in forum DynaTorch
    Last Post: 10-14-2007, 12:46 AM
  5. Keeping the 'puter clean
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 01-01-2004, 12:30 AM
