Hi Folks,
i have a 600x900 laser cutter with an 80w tube, bought from china. It uses this controller:
What i found initially, was the scaling was a bit off. So if i used the machine to cut a 3cm x 3cm square, it was 3 and a bit cm's; workable, but not ideal.
What i found is that when i used the supplied rotary tool, the scaling was worse and the image was was trying to engrave seemed like it was stretched.
I recently had a power outage in the middle of a cut, and i'm now getting a "No Enough Extend Space error" :-/
i've read a fair bit on the forums and i'm looking to do two things:
- confirm that the scaling was actually setup for the stepper motors the first time correctly. Could someone give me some guidance on how to map the X & Y stepper motors properly to the controller settings in RDS works Vendor settings?
- Confirm that the laser head actually knows where it is relative to the working area to prevent the no space error?
thanks!
Nathan
