502,816 active members
4,545 visitors online
Results 1 to 6 of 6
    Registered
    Oct 2017
    25
    How Is This Possible?
    How would this be manufactured?
    https://www.my737ng.com/hardware/sim...ontrol-column/
    Single piece of metal, hollow (to allow for wiring). I don't have one to dissect, so I'm not sure if it's two pieces that are welded together and then sanded smooth, but I have a feeling it's cast somehow as a single piece, but how would you get the hollow middle?
    Any ideas?
    Member
    Feb 2008
    440
    Re: How Is This Possible?
    Quote Originally Posted by Shabalala View Post
    Any ideas?
    Says its made in Fibreglass not metal - so obvious way is two part mold either done separately and joined or joined 'wet' as a single assembly.
    If it was metal it could be tumble cast - pour measured quantity of metal into mould then 'tumble turn it through all axis to coat the mold walls whilst leaving void internally! Or traditional lost wax type casting..........many ways to skin a cat!
    Registered
    Oct 2017
    25
    The one that's made in the link is fibreglass. The real one is made of metal.
    Thanks for the suggestions, will research in that direction!
    Jul 2018
    543
    It says its made of resin so probably a tube (metal or plastic) is placed inside the mould that creates the wiring path, then resin is injected into the mould and around the tubes. The steering metal insert is also co-moulded. Cheers Peter
    Registered
    Aug 2016
    86
    Sand casting, investment casting, or metal injection molding are all possibilities.
    Registered
    Oct 2017
    25
    Thanks, looks like home made isn't the name of the game for this, but still looking into this. Fibreglass is always an option.
