585,741 active members*
4,989 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Need help brainstorming a solution for this mill turn spindle
Page 1 of 9 123
Results 1 to 20 of 174
    Nov 2017
    591
    Im wanting to build a horizontal spindle for my mill that will double as both a lathe and a 4th axis, mostly for smaller diameter (roughly up to 2 inch max diameter) aluminum parts, turning with tools mounted to main milling head and index milling with main spindle. At this point im leaning towards a foundation of a premade dunham 5c headstock/spindle. Seems to be pretty good quality, very low runout, 5c taper is ground after mounted, 1700 bucks. The challenge is choosing a proper servo to drive this thing and come up with a solution that will give enough rpm as well as enough holding torque and resolution for 4th axis operations. These are the goals:
    1-At least 2500rpm for turning, more is better, 4k would be great
    2-At least 1hp for turning. Smaller aluminum parts so don't need crazy power
    3-A minimum resolution of .01 degree step for 4th axis operation. 90 percent of what I'm doing doesn't require this kind of resolution, but one exception to the small aluminum parts is hobbing large helical delrin gears, about 4inch diameter so .01 degree step will be about 3 tenths on the edge of a gear. Higher resolution would be better, but I figure this is a minimum.
    4-enough holding torque for indexing a mini horizontal tombstone with tail stock support, smaller tools up to 1/4inch machining out at a max radius of 2.5 inches, only light machining, rarely more than 1 cubic inch mrr, no drilling larger than 3mm.
    5-budget of 3500 max including the 1700 dollar headstock /spindle
    At first i was hoping to find a powerful enough servo to do all this without changing gearing, but after some research it doesn't seem too realistic. A big 1200 dollar clearpath servo will give far more than enough power, 2700rpm, and probably just enough holding torque (4800oz/in) with direct drive, but not quite the resolution i need. This would give .03 degree resolution which would be about a thou step at the edge of a 4inch gear, don't think that's gonna cut it for precision hobbing. So the main challenge in my mind is figuring out how to give this thing 2 gearing options that can be swapped fairly quickly, better yet an automated changed over. If I choose a more realistic size nema 34 dc servo, it wants to run somewhere between 1 to 1 and 2 to 1 ratio for turning, and between 5 to 1 and 10 to 1 for indexing. 10 to 1 or more would be preferred. Pulleys and belt is fine for the turning, but a 10 to 1 ratio with a belt for indexing isn't really optimal. Not sure what kind of rigidity and backlash I can count on with that. Then I was thinking maybe somehow use harmonic drive for the 4th axis reduction and belt for turning, but I would still need to place the harmonic drive next to the spindle and drive it with a 1 to 1 belt since it's a 5c spindle and harmonic drive can't couple directly to the back of it.
    So, any ideas of the best way to tackle this? Would be great if there was a servo capable of what I want with only one gear ratio and within the budget, but I don't think that's realistic, so the main puzzle is coming up with how to give this thing 2 quickly swappable gearing options (automated would be great) to meet the goals.
    Dec 2013
    5717
    Re: Need help brainstorming a solution for this mill turn spindle
    An interesting dilemma. Speed, accuracy, cheap, pick any two. I'm going through somewhat the same thought process on my lathe which right now does not have spindle indexing capability, but does have live tooling. 7.5 KW (10HP) spindle, just to make it more interesting.
    In your case, why not put the spindle motor of your choice on the spindle, any cheap motor would do for turning. Then a separate small servo motor with a timing belt drive, driving a large sprocket on the spindle. But the sprocket freewheels until you lock it to the spindle. The sprocket lock mechanism could be as simple as screwing in a bolt, pushing in a pin, or for full automation could use an automotive air conditioner clutch (those will transmit an immense amount of torque, around 10 HP worth). For additional holding power, you can always add a disk brake, motorcycle or go-cart parts.
    For servos, take a look at DMM Tech products also.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    591
    Not a bad idea. Probably even cheaper. To get a servo that will provide the needed power for turning, it's 600 bucks minimum. If I separate it into a servo and a bldc motor, the servo doesn't need nearly as much power for the indexing as long as it's geared down enough, more like 300 dollar servo. One hang up I have on the heavily geared down servo though, 10 to 1 with pulleys is gonna be a huge pulley and a tiny pulley, i dont picture the tiny pulley holding onto the belt with total rigidity during indexing. I can imagine there will be a tad bit of give there. Maybe not as bad as I think. I guess there's still the option of putting the servo on a 50 to 1 harmonic, then link that to the spindle with 2 decent size pulleys. Then i would have all the resolution i could ask for and still probably 100rpm after 50 to 1 gearing which is plenty snappy for a 4th.
    Actually that gives me a good idea. Only 2 pulleys, one on the spindle, one next to it. The pulley to the side is supported by it's own bearings with a shaft protruding out both sides. One end of that shaft will have a link to the harmonic reduced servo, other end linked to bldc motor. Some kind of detachable coupling for both ends or clutch system. I'll take a look at the a.c. compressor clutch mechanism. I can also picture some kind of 2 in 1 actuated system. Dowel pins passing through that offset pulley. When pushed one way or the other, they will disengage one and engage the other in one single mechanism. Hmm.i think I can start playing around on cad now, see how this will lay out. Thanks for the dual motor idea, might make the most sense.
    So along the lines of picking a bldc, what would you recommend? Does 2hp come in a pretty small package? How do you control it with mach3? Guess I can probably figure that out if I look. Never used them before
    Dec 2013
    5717
    Glad I could get the creative juices flowing
    Maybe this spindle motor would work, as far as I know it does not have indexing capability. It is compatible with Mach3.
    https://www.automationtechnologiesin...or-and-driver/
    Automation Tech has a number of steppers and servos available also.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    591
    Yep, something like that would be perfect. Looks like it takes 0-10v analog input so I assume I just need an encoder pulse on the spindle and mach3 can take it from there. That pulse could also double as a home switch for A.
    I also just realized I could probably use something I already have. My main hobby that drives the machining hobby is rc helicopters. Have a few spare motors for those. They are pretty impressive little motors, smaller than your fist, capable of 3kw continuous easily, 10kw burst. Would just need a dc power supply and an analog 0-10v to pwm converter to control the esc with mach3. Kind of mind blowing how such a tiny motor could put out that kind of power. Only thing is, those escs don't like low duty cycle with heavy load so would need to be cautious of that but definitely an option
    Dec 2013
    5717
    I'm no expert in Mach3 and breakout boards, but I think Mach3 outputs a PWM signal that is converted to 0-10V with a low pass filter on the board. So all you would have to do is bypass the filter to get a PWM output. Maybe this would work with your RC hardware.
    Worst case, since you already have the parts on the shelf, is that if it doesn't work you just switch over to a known system. Might be worthwhile to see if you can control a RC motor with Mach3 on the bench.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by QuinnSjoblom View Post
    This is one you may get some Ideas from WebPageMain, he uses a servo motor with a direct drive ratio and a backgear for low speed
    Mactec54
    May 2015
    1422
    Not sure of the power etc, but I'm waiting on a mill turn machine at the moment that uses hefty hobby king sized BLDC motors running off an o-drive board. I'm not sure whether I'm going to have to change the A spindle out for something similar to what you're looking for but the designer of the machine reckons (and his videos seem to show) that the BLDC off the O-drive gets the job done nicely.
    https://www.kickstarter.com/projects...ur-machine-sho
    May 2016
    316
    Cheap 5C spindle harvested from a spin indexer. Deep groove bearings in an aluminum housing. Bearing seats were line bored in place with the 4th axis.
    Taper has essentially no runout measured with a 0.00005 B&S indicator. Threaded the outboard end for a clamping lock nut with two holes to mount a GT2 pulley.
    Using it as a tailstock for my 4th axis, but could be powered with a servo down the road.
    Way, way cheaper than the spindle you're considering.
    May 2016
    316
    BTW, go check out the InTurn from Cube Studio. Lots of Youtube videos, and the early ones show some pretty basic stuff like I built.
    Aug 2016
    132
    One example: https://www.instagram.com/p/BsCHjVMoCQv/
    Another vote for DMM. The 1.8kw 120-DST-A6HK1 with a DYN-4 and cables will be around $700. Resolution under .0001 degrees and a 24VDC brake.
    Nov 2017
    591
    Quote Originally Posted by footpetaljones View Post
    That servo looks very impressive. Much more compact than the clearpath I was looking at, also much cheaper. When you say a resolution of .0001 degrees, are you referring to the machine in the Instagram post, with some kind of gearing? I'm having a hard time finding what resolution the motor is without gearing. Says 16bit encoder, but I don't know what that means, totally new to servos. I would be running this with mach3 and ethernet smooth stepper.
    May 2015
    1422
    16 bit = 2^16 or 65536 positions per revolution, about 0.005º resolution.
    May 2016
    316
    (Anyone else feel free to chime in if I get something wrong here)
    If you're rconsidering ESS/Mach/DMM, then the limiting factor for angular resolution is speed vs. pulse output to the servo drive.
    Lets say you have a 1:1 motor to spindle pulley ratio. If you want to spin the spindle at max motor RPM (3000 for the DMM 1.8kw), then you have to figure out how many pulses per second that is at direct resolution in the servo.
    The servo has ~65k encoder positions per rev. That means you need to send 65k * 3000RPM /60 (sec/minute) = 3.2Mhz (millions). The ESS is theoretically capable of outputting that number of pulses per second, but I'm not sure Mach3 or your computer is. And the DMM DYN4 drive is limited to 500khz input.
    Enter electronic gearing.
    The servo drive is capable of moving the motor various number of encoder counts per input pulse. You set the gearing to "4" (or whatever) and 1 input pulse (from Mach/ESS) results in a motor move of 4 encoder counts. At the hypothetical "4" electronic gearing you will need 3.2Mhz /4 = 812khz pulses to move the motor at 3kRPM. Still too fase for the DYN4 drive.
    Change that to 8:1 gearing and you're down to 406khz(ish): In the ballpark for the DMM maximum pulse input speed.
    The tradeoff with gearing is that you lose resolution. At 1:1 electronic gearing, one pulse will move the spindle 0.005 degrees (based on dharmic's post above), or 0.00026" at the outer edge of a 6" circle (your chuck or whatever). At 8:1 gearing, you get .002" of movement per input pulse at 3000RPM with a direct drive motor to spindle.
    Bringing us to the motor to spindle pulley ratio. You'll want, as you discussed, two gear ratios - one for indexing and low-end torque, and another for turning small stuff at high speed. If we set the two ratios at 3:1 (high) and 12:1 (low) you'll have a top speed of 1000RPM and 250RPM.
    Assuming the 8:1 electronic gear ratio, at 1000RPM you'll have three times the resolution as the 1:1 ratio. So about 0.0007" per pulse. At low ratio, you'll be back down to around 0.0002" per pulse.
    And that's at the outside of a 6" diameter part. Divide by 3 for your intended 2" (and smaller part) and you're down in the 0.00006" range per pulse output.
    This is just the math, of course. At that fine a resolution everything is flexible - the belts, the collet, the part, the temp, the weather. You aren't going to be able to repeatably index in the millionths of an inch, but you should get the point.
    Even if you change the pulley ratios to get 1500 or 2000RPM on the spindle for small stuff, with a 'backgear' you'll still have a mechanical (theoretical) resolution much finer than I expect you need from a home-brew dingus.
    To sum up... The DMM/DYN4 combo will get you the speed you'd like for turning small aluminum parts, as well as very fine angular resolution for cutting splines and other critical features (rotationally speaking) - assuming you set up the pulley ratios appropriately.
    Again, check out the Cube Studio stuff. He has a brilliant double-reduction back gear + direct drive setup. Frankly, if you were considering $1700 for a spindle by itself just BUY one of his Mega 4th axis packages. Even comes with a control system that looks amazingly slick.
    Nov 2017
    591
    Quote Originally Posted by dharmic View Post
    Wow! That is impressive! I could gear the thing 1 to 1 and have plenty of accuracy. What's with the 24v brake? Can't find much detail about that either. If it allows for a really locked position, it kind of sounds perfect for my application.
    So .005 resolution, that's 72000 steps per rev, whuch is 3.6mhz at 3k rpm. smoothstepper can be set up to 4mhz. Looks like I'm right at the limit for using full resolution up to 3k rpm, unless I'm not understanding that fully. Really curious about this servo now and need to learn more about it.
    Nov 2017
    591
    Quote Originally Posted by spumco View Post
    Ok, so Im definitely not gonna be running this thing up to 3k rpm at full resolution. Too much for the driver to handle. I'm really curious about the 24vdc brake. Not sure what exactly that does, but it might still be possible for me to just keep this thing at a fixed ratio for most work which would really be nice, but I guess I would at least have to switch the electronic gearing back and forth from high resolution at low speed indexing, to lower resolution at high rpm turning. I guess it's probably not any more hassle to leave electronic gearing alone and have different actual gear ratios to really get optimal torque and speed for turning/indexing. I'm really curious how the 2 stage gearing was handled on the inturn. Need to look into that more.
    Nov 2017
    591
    The inturn mega looks like a great machine, but it's still a pretty large price gap even if I do build this around the dunham spindle. The mega is 3 grand and that's no servo included, more like 3800 when you're done. I think I could do this for about 2600 using the dunham spindle. It won't have the disk brake like the inturn, but I don't think I'll need it for index work on 2 inch aluminum parts as long as I have a decent servo and gear down for the index work. Using a 5c indexer spindle and building my own headstock is an option, but I don't think I would get as good of results. For one I don't have capability to line bore the whole assembly with the equipment I have. The dunham spindle is really pretty sweet. Nice solid cast headstock, spindle is assembled into headstock, bearings preloaded, then spindle taper is ground. They guarantee runout less than half a tenth. Also it has a 4 degree taper nose to allow use of hardinge closer rings for big step chucks.
    15362
    You don't loose any resolution using electronic Gearing, the Encoder resolution does not change
    DMM also have a 32Bit Encoder if someone wants an even better positioning resolution
    Mactec54
    Nov 2017
    591
    You don't lose accuracy of position, but you lose steps per unit, each step it receives from smoothstepper will be multiplied by gearing. Right? Only way to make higher rpm manageable by the drivers frequency limitation
    15362
    Your Step / Per you can control with Electronic Gearing like if you used DMM and set 500 for the Electronic Gear number it would only be 2,000 Steps / Per rev
    The Brake on a Servo Motor is not suitable for positioning, they are only used for when you power off the Servo Motor, if you want to activate a brake then it has to be independent of the Servo motor Brake
    Mactec54
Page 1 of 9 123
  1. UPGRADING THE MILL TURN SPINDLE FOR HIGH SPEED USE III
    By JTJT in forum Shopmaster/Shoptask
    Last Post: 09-20-2016, 01:22 AM
  2. Fix for Noisy/Hot Mill-Turn Spindle (& other upgrades)
    By n1tr0 in forum Shopmaster/Shoptask
    Last Post: 09-16-2016, 06:33 PM
  3. Replies: 0
    Last Post: 04-01-2016, 07:55 PM
  4. Replies: 0
    Last Post: 04-01-2016, 07:52 PM
  5. how to turn on spindle while mill spindle is on!!
    By the mill kid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2010, 08:08 PM
