585,715 active members*
4,524 visitors online*
    Jan 2010
    76
    Offset for z axis gauge block height
    I have a simple touch plate where an LED lights up when the tool makes contact with the touch plate. Mach 3 had an offset for gauge block height and I just switched to UCCNC so I am trying to find the analogous functionality in UCCNC. Since this is not hooked in to my IO I can’t simply run the auto zero macro. Any help is appreciated.
    Apr 2014
    59
    Re: Offset for z axis gauge block height
    When you touch the probe you can simply enter the height of the block to the Z DRO.
    Jan 2010
    76
    Quote Originally Posted by dezsoe View Post
    Ok thank you very much!
    The latest test release as a probing plugin, which has a gauge block setting.
    forum.cncdrive.com • View topic - UCCNC test releases posted in this thread
    It also has at least 100 other new features. But keep in mind, it is a TEST release.
    Jan 2010
    76
    Thanks, I will take a mental note to download once it becomes a stable release. Ger21, your endorsement of UCCNC in previous posts was one of the main reasons I made the switch!
  1. Discovery 308 Set Gauge Height
    By jthornton in forum Bridgeport / Hardinge Mills
    Last Post: 04-28-2016, 12:23 AM
  2. Replies: 3
    Last Post: 09-03-2015, 04:01 PM
  3. gauge block settings
    By rod5858 in forum CNC Wood Router Project Log
    Last Post: 11-19-2013, 02:01 AM
  4. Z axis height and spindle mount offset
    By TiagoSantos in forum DIY CNC Router Table Machines
    Last Post: 01-14-2012, 04:05 AM
  5. Height Gauge Opinion
    By thedave in forum Calibration / Measurement
    Last Post: 07-21-2010, 12:09 AM
