585,728 active members*
4,120 visitors online*
    Mar 2005
    271
    Wrong Voltage whoops....
    OK I'm an idiot, I was doing some rewiring and I accidentally wired 120v with 240v and it blew a variristor. So I replaced the variristor and wired it properly but now the servo drives won't power up. Is there something I am missing it seems like everything else in the panel is fine.
    Any input would be greatly appreciated.
    Thanks Mike
    Nov 2012
    1267
    Re: Wrong Voltage whoops....
    Check the parts with a meter, starting with the power circuits: fuse, diode bridge, output transistors. Measure the voltage on the big capacitors (very carefully). If everything is fine there, check the low voltage power supply.
    Mar 2005
    271
    Quote Originally Posted by CitizenOfDreams View Post
    OK thanks for the reply.
  1. Chinese VFD - Wrong Voltage?
    By firepong in forum Spindles / VFD
    Last Post: 06-13-2018, 05:36 AM
  2. EDM wrong direction of eroding, no voltage
    By qmq in forum EDM Discussion General Topics
    Last Post: 08-21-2016, 11:23 PM
  3. Spindle too fast, wrong voltage going to VFD
    By geofox784 in forum Spindles / VFD
    Last Post: 07-06-2015, 07:26 PM
  4. Bought the wrong voltage motor, any change possible?
    By HereinCS in forum Servo Motors / Drives
    Last Post: 09-01-2010, 05:29 PM
  5. Whoops
    By Geof in forum Haas Lathes
    Last Post: 07-04-2008, 04:34 AM
