585,978 active members*
4,586 visitors online*
Results 1 to 9 of 9
    Stepper Motors
    I have a Xylotex 3 axis board with 4 wire steppers (Nema23), Mach3, XP Desktop, HP 20.7" flat monitor. When I jog my motors 4 inches, the Mach3 DRO shows 4 inches but actual travel of my mill table is only about 3/8 of an inch. Motor tuning is:
    Steps Per - 2000, Velocity 175, Acceleration 25 and the Pulse - 1 and 1.ted. Thank you,
    Suggestions appreciated. Thank you,
    Ray
    Apr 2004
    5737
    Re: Stepper Motors
    What happens when you up the "steps per" by a factor of 10?
    Andrew Werby
    Website
    35538
    Re: Stepper Motors
    Is it lead screw, belt drive, rack and pinion?
    What's the gear ratio of the system.
    The default Xylotex setting is 1/8 microsteps, or 1600 steps per stepper revolution. So I doubt 2000 steps/inch is the right number.
    Also, set the pulse widths to at least 2 or 3, instead of 1.
    And make sure the Mach3 default native units are the same units you are using.
    Feb 2022
    Re: Stepper Motors
    Xylotex settings is confusing for me.
    divorce counseling
    Mar 2022
    Re: Stepper Motors
    You earn an automatic share on my Fb profile for writing this.
    https://www.emondagesaint-augustin.com/
    Apr 2022
    Re: Stepper Motors
    I would recommend in regards.
    emondage
    Jul 2022
    Re: Stepper Motors
    Now it's not actually what we expect.
    http://www.emondage-quebec.ca/essouchage.html
    Aug 2022
    Re: Stepper Motors
    I give me something.
    elagage
    Oct 2022
    Re: Stepper Motors
    I really enjoyed this.
    essouchage
  1. Current Settings for KL4042D Stepper Drivers and Stepper Motors
    By New Lathe Man in forum Benchtop Machines
    Last Post: 04-02-2017, 12:43 AM
  2. servo motors or stepper motors for ATC machine
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 04-21-2015, 03:29 AM
  3. 20 stepper motors + 9 normal motors
    By Yaro in forum For Sale Only
    Last Post: 08-08-2014, 09:57 AM
  4. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  5. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
