Hello. I'm using Alphacam Ultimate Router 2017 R1
I want help with tool defining, in alphacam.
Imported the tool foto.
I did the tool drawing, defined it as USER-DEFINED. And it works only on simple commands like, pocketing, drilling, finish milling ect. I can't use this tool with commands, 3D (surface,solid machining) getting error (tool must be ball end). If i'm using advanced surface, wire frame,multi axis or swarf machining command, alphacam just crashes.
So question, what i did wrong? How to define specific tool for 5Axis machining? Adding couple pics, and ard file with tool drawing and task which i what to complete.
Silvestras
