585,974 active members*
4,304 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura Minisuper 300 Retrofit
    Hello,
    I could get a Kitamura Minisuper 300 from 1987 from a spanish campany in my near. The machine fails in the electronic, and the old owner has bought a new machine with the same control, so he take out all electrical/electronical components as spare parts.
    My idea is, to strip down the machine, clean all parts, new color, replace all damaged parts, change the ATC to a newer/faster mechanism and replace the elecronic with a Beamicon2 control.
    The machine comes with a truck, but the crane could not place in my workshop. After 14m he stopped, because the machine was to heavy.
    So I must drop outside in the street.
    Re: Kitamura Minisuper 300 Retrofit
    Here the next part:
    Ok - now I need to dissamble the machine. Kitamura has a very nice machine build. All it?s very clearly mounted, you don?t need special tools.
    Someone has rebild the machine and used Turcite-B, but the oil-channels milled through the material - this is very bad for the stability and for the glue.
    And here I ordered the new Turcite-B:
    Turcite-B
    Take off the old cables, trafos etc. was 148kg, and I?ve got 43Ç from the recycling company :-)
    (to be continuied....)
    The ball screws:
    and the last parts for cleaning:
    I think I need one or two days more to take off all the old oil, grease, chips...
    Then I can start with the painting task.
    This week I must also get the new Turcite-B films, so that I can start with glue them. After this job is done, the cross table was shipped for flat grinding in a special workshop (on the other side of spain).
    The fanuc servos I will replace with Moog-Servos (due the encoder problem of the fanuc ones. They have pulse encoder but only a poor graycode for the UVW).
    So far for this week...
  1. Kitamura MyCenter 1/485 - ground up rebuild and retrofit
    By t_hum in forum Vertical Mill, Lathe Project Log
    Last Post: 01-31-2019, 05:26 PM
  2. Replies: 0
    Last Post: 11-25-2017, 05:32 AM
  3. Kitamura Fourth Axis Retrofit?
    By CNC Biker in forum Want To Buy...Need help!
    Last Post: 04-09-2014, 04:26 PM
  4. Kitamura Fourth Axis Retrofit?
    By CNC Biker in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2014, 04:23 PM
  5. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
