585,951 active members*
4,320 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
Page 3 of 5 12345
Results 41 to 60 of 91
  1. #41
    15362
    Re: Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
    Quote Originally Posted by cduncan64 View Post
    Didn't realize how expensive enclosures could be.
    Saw this steel tool cabinet at a store nearby.
    Its 28" x 28" x 12" for $80.00 Not very dustproof since there are no seals, but that's an easy fix.
    Charles
    Yes you should use a Power Filter on the input side of the VFD it needs to be rated for the same size as the supply Circuit more is better
    The VFD should never be turned off, the Main Power should not be in the EStop Circuit, only the control or fault Circuit is used in the EStop Circuit, if you cut power to a VFD and the Spindle is running you usually smoke the Drive or the Spindle this only applies to these high speed spindles
    The cabinet looks ok but you will have to add a Back Plane this is done by adding some standoff's and attaching the Back Plane to the standoff's, ( Aluminum Plate )You could leave the shelf as you could separate the power supplies and VFD from the low voltage electronics
    The door could pose a problem as they need to be fastened some how so the can't be opened easily, a fan should keep most of the dust out
    Mactec54
  2. #42
    Jan 2017
    31
    What is the purpose of the backplane?
    It's not electrically isolated from the cabinet, is it?
    again, thanks.
    Charles
  3. #43
    15362
    again, thanks.
    Charles
    Back Plane is what you mount everything on all electrical cabinets have a Back Plane of some kind, the Back Plane is not painted for better Grounding the Back Plane is Grounded with the main input power supply Ground and then the Box and Doors are Grounded to the Back Plane
    Mactec54
  4. #44
    Feb 2019
    15
    Ok, this morning my VFD died. YL600-2s-2k20 for 2.2KW spindle. This was bought from a company that said it was able to use 110V. No smoke, no pop, just the slow winding down of the spindle. The display on the VFD had something on it (CN????) but before I could read it, the display went off. Powering off/on did nothing. Connections look good. Power is there. One tiny LED D12 is on, that is all.
    I've had the VFD for about two years.
    So, that brings me to now. I'm looking at some VFDs on Amazon and am looking at 220v models such as:(VFD 220V 3.0KW 4hp Variable Frequency Drive CNC VFD Motor Drive Inverter Converter for Spindle Motor Speed Control HUANYANG HY-Series(3KW, 220V))
    or should I step up to the 4.0KW 5.5 HP?
    Any suggestions?
    If you have a similar setup, I'd like to hear from you as well.
    Thanks!
    Charles
    Five HP is better,
  5. #45
    15362
    Quote Originally Posted by atocom View Post
    Five HP is better,
    Not for a 2.2Kw Spindle
    Mactec54
  6. #46
    Jan 2017
    31
    mactec54 or anyone else,
    Is there a wiring diagram for wiring the power inside an enclosure?
    I'd like to see what other people have come up with.
  7. #47
    15362
    Ericks has a good example has a lot more in his cabinet than you will need but will give you an idea, if you go through his whole electrical cabinet build
    https://www.cnczone.com/forums/diy-c...nc-cad-25.html
    Mactec54
  8. #48
    ericks Guest
    That is true....i have a lot of junk in there
  9. #49
    ericks Guest
    Why do you want to use such a big enclosure/box?
  10. #50
    Jan 2017
    31
    Greets,
    What type of wire can I use to connect the din rail terminals to my circuit breakers? Stranded or solid? Type?
    Also, the other things that need power (PC, Monitor, Smoothstepper power supply (wall-wart), Stepper Motor Power Supply, Flood Pump, Vacuum, Lights) should they all be brought in and powered within the box?
    If so, maybe I should install a second circuit breaker (using the other half of the 220v) that way I can balance things out better? Like, two separate 4 gang outlets.
    Thanks, Charles.
  11. #51
    ericks Guest
    I always use fine stranded cable (control cable)....in control panels
  12. #52
    Jan 2017
    31
    Quote Originally Posted by ericks View Post
    Hello ericks,
    I do appreciate the reply. I should have been more detailed in my question. I need a vendor or source located in the US. If possible a website or a manufacturer's part number.
    Also, how's is your CNC coming along? The last post I saw was some test cuts.
    Thanks again.
  13. #53
    ericks Guest
    Hello ericks,
    Thanks again.
    No worries i am sure someone that side will give you good advise on a supplier. My cnc is great thanks for asking.....been busy working on router control panels/testing so i have not had much time to make parts on it. The pendant is also still in the box
  14. #54
    ericks Guest
    Check out my build thread.....i just cut out a 20 mm steel disc
  15. #55
    15362
    Hello ericks,
    Thanks again.
    Depending on what you need, IGUS Chainflex is a very good supply for shielded and unshielded cable, and McMaster Carr also have some very good cable to use there are many suppliers I use both of theses suppliers
    Mactec54
  16. #56
    Mar 2015
    23
    I am setting up my vfd and spindle using the same components in this thread, 3kw VFD and 2.2 KW spindle. With an input of 220V single phase 25-30 amps how do you connect 10ga wire to the ridiculously small R and T terminals on this drive? Where do you find wire lugs small enough to fit the small terminals but will still work for 10ga wire.
  17. #57
    Jan 2017
    31
    I'll check in the morn.
  18. #58
    15362
    Quote Originally Posted by Rickpt View Post
    There are other suppliers also https://www.ebay.com/itm/10-Pcs-Ring...sAAOSwiYlaJkSB
    Mactec54
  19. #59
    Mar 2015
    23
    Those are just like the ones I have, too big to fit the tiny terminals. I will keep searching they have to be out there somewhere.
    Hard to believe those tiny M3 screw terminals can handle 30 amps.
  20. #60
    15362
    The small size usually comes in the kits
    Mactec54
Page 3 of 5 12345
  1. Buying new Chinese ATC spindle.
    By 520052 in forum Chinese Machines
    Last Post: 05-12-2020, 05:42 PM
  2. Buying a VFD Spindle
    By basha318i in forum Spindles / VFD
    Last Post: 04-05-2018, 09:41 PM
  3. Replies: 16
    Last Post: 09-23-2015, 11:54 PM
  4. X3 spindle motor died - Any easy retrofit solutions?
    By pumpercloggs in forum Syil Products
    Last Post: 02-16-2014, 10:25 PM
  5. Replies: 8
    Last Post: 11-21-2013, 06:53 PM
