586,024 active members*
4,064 visitors online*
    Feb 2019
    41
    Seized Ball Screw
    Evening all,
    I apparently over extended my double ballscrew and caused it to Jam. I was able to to get the one half that was jammed off. But when I re-packed and put it back on, it seized and now won't twist enough to get it off. Am I totally screwed, or is this something that can be fixed? If it can be fixed, how?
    Thanks for your time.
    Feb 2019
    41
    Re: Seized Ball Screw
    Ok,
    I got it unseized I've got it repacked, and I've got it back on the ballscrew. What is the proper procedure for combining the two nuts? There are the two half ring things, with the two bars and screws. I have it back together now, with the slightest amount of play between the two. Is this normal?
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  3. Adding ball screw to lathe for Electronic Lead Screw
    By harrzack in forum Hobbycnc (Products)
    Last Post: 12-28-2018, 03:28 PM
  4. collet set screw seized.
    By 356911914 in forum Hardinge Lathes
    Last Post: 03-19-2013, 01:45 AM
  5. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
