585,931 active members*
3,646 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa CACR-IR30SEC-AY20 AC servo drive
    Jan 2006
    15
    Hi all,
    I got my hands some servo drives, now I'm looking for a way to use them. Have read the available docs about how to drive them. RS422 and PWM inputs are used to control. The RS422 is clear but what the PWM control method means?
    Any help would be appreciated.
    Apr 2013
    Re: Yaskawa CACR-IR30SEC-AY20 AC servo drive
    i have some of these also, any luck on driving them.
    i have some ideas on how the current command works
    First is Quadrature Differential PWM, so basic encoder input.
    there is some math in the current command section the uses the same encoder count as the encoder on the motor this would be a simple way to give a current command from the NC.
    Second is would be U phase PWM is CW current, and V phase PWM is CCW. this would also be a simple way of controlling from an NC.
    Third could be direct current control of the UV phase with the CPU filling in for W. if this is thee case would not even know were to start with controlling them.
    will have too use a differential driver IC no matter what the signaling is because the Error signal for the pwm lines monitors the voltage difference directly from the input lines.
    i have plans to put a test system together soon. any input would help trying to get my motoman 150 running
    Jan 2006
    15
    I had to give them away, sorry. But keep posted your results, many of us are interested.
  1. Yaskawa CACR-SR
    By flinty in forum Servo Motors / Drives
    Last Post: 08-28-2018, 01:52 PM
  2. Yaskawa Eprom IC for servo drive CACR-IR 1OSB
    By nice-day in forum Servo Motors / Drives
    Last Post: 02-12-2015, 03:17 PM
  3. Initializing servo amplifier Yaskawa CACR-IR30
    By ing.vic in forum Servo Motors / Drives
    Last Post: 09-02-2012, 10:31 PM
  4. yaskawa CACR HR10SB servo pack
    By vipansam in forum Servo Motors / Drives
    Last Post: 12-07-2009, 05:39 AM
