585,741 active members*
5,335 visitors online*
Results 1 to 20 of 20
    Nov 2018
    16
    Unhappy Motor Timing Pulleys
    Finally got my Nema 34 motors but the motor timing pulleys that Nate sent had the small key ways. I've sent msg. to FLA. I saw where Ntl had the same problem but I did not see what the final outcome was. Any input Ntl. Don't know how long to wait this time.
    Aug 2018
    621
    Re: Motor Timing Pulleys
    Quote Originally Posted by Joesmo View Post
    Yes had the same thing happen, he took 6 weeks to get me the correct ones. But they are from CNCrouterparts so you may want to give them a call if you don't hear from him. I saved the box that has the cncrp part number so I can call them if I need a replacement. Let me know if you need me to give you the part number, I just need to unbury the cabinet that I have my boxes in.
    Dan
    Nov 2018
    16
    I was afraid of that. I can't wait another 6 weeks. It took me over 8 weeks to get the motors and then I had to get them from CNCrouterparts. Wearing thin.
    Sep 2005
    1740
    No Excuse.
    Aug 2018
    621
    Fortunately I had read from others not to buy the electronics from them since they get them from cnc router parts anyway. I can't understand how months later the same thing happened to you. I'm happy with my machine, but the non existence of after sale support really blows. Good luck buddy and let me know if you need me to find the part number for you. I looked all over the internet for the pulleys before they finally showed up and I couldn't find anything, I think they're custom made for Finline.
    Dan
    Sep 2017
    78
    Nate is notoriously slow to respond. After we had been told that our machine had shipped I realized that he had, in fact simply created a shipping number and used our machine to film a video for this forum during the time we were waiting for shipping confirmation. When it arrived we saw he had not repacked much of the hardware for the drives. A month later and multiple calls, emails we finally got them. After installation and a couple of weeks of use the slave side drive developed all kinds of slop, misalignment, etc. Rather than wait for Nate to replace it we opted to order new ones from CNCRP. Got them two day later and they've been great.
    The good news is that Nate refunded the price of the returned parts in full!
    Saturn 2 4848
    CRP Plug & Play NEMA 34, 2.2kw Spindle, Mach3
    Aug 2018
    621
    Did you ever get the pulley's?
    Sep 2005
    1740
    I have seen special keys made, small on one side larger on the other. Or can the pulley keyways be cut larger?
    Aug 2018
    621
    Quote Originally Posted by wmgeorge View Post
    Yes it's simple for a shop that has a press and the right tooling to open up the keyway slots. It's called internal keyway broaching, the company that I bought my finger break kit from sells the tooling. But it's probably cheaper to just buy the right ones from CNCrouterparts.
    https://youtu.be/jHPLyPjiF-I
    Dec 2013
    5717
    Or use a lathe to broach the keyway. I needed a 6mm keyway in this sprocket and didn't have a 6mm broach, just ground a tool bit to size and became a manual shaper.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    1740
    Jim, Darn it I forgot about that method and I have lots of HSS bits I could use. Thanks for posting.
    Nov 2018
    16
    Still no response from FLA. Thanks for all the suggestions but I do not have milling equipment. The easiest and right way to do it, is to just have the parts replaced by FLA. I'm old school and believe you should fulfill a paid contract.
    Aug 2018
    621
    Maybe get the price for them from cncrp and tell fineline that you need a refund for the the amount of the pulley's. See if they respond to that, I wonder also if the pulley's are custom made for them since I never called to see if they stock them. Either way you're 100% correct that you shouldn't have to deal with this. I still am amazed that fineline has lasted this long after my experience with the company.
    Dan
    Sep 2017
    78
    $16.25 each from CNCRP for NEMA 34 pulleys. I agree, FLA should honor their commitments, but we decided to order the missing parts from CNCRP and Nate did come through with the refund. Not worth the frustration.
    Saturn 2 4848
    Nov 2018
    16
    I got a response from Nate couple of hrs ago but I'm not sure he understood what I needed. His response was that they do not have Nema 34 pulleys with 1/2" key slot. I had requested from him Nema 34 pulleys 1/2" diameter with 5mm key slots.
    I responded with a clarification but haven't heard back.
    Nov 2018
    16
    Does everyones timing pulleys have key slots and set screws? I was looking at the ones form CNCRP and they only look like they have set screws. I would think that the key slots would be a must.
    Aug 2018
    621
    Mine have both the keyway and set screws. Like I said earlier they came in boxes with cncrp part numbers on them. I saw that as well that the pictures they have don't have the keyway. But their website doesn't look like they update it very often. You should just call or at least email cncrp they might be a special order part. I don't think that they were repackage and I still don't understand why fineline won't send you the correct ones since you paid for them. Worst case you can probably file the slots to open them up, or find a local machine shop and have them open up the keyways. That's what I was going to do if I didn't get the right ones. I'm not sure what would be cheaper, buying 3 pulleys or having the wrong ones machined.
    Sep 2017
    78
    Ours are from CNCRP. They have both keyways and set screw.
    Saturn 2 4848
    Aug 2018
    621
    Quote Originally Posted by micknm View Post
    Just curious did you order them from cncrp or get them from Finline?
    Sep 2017
    78
    Quote Originally Posted by Ntl View Post
    CNCRP
    Saturn 2 4848
  1. How to match Timing pulleys and timing belt? (noob question)
    By cdesantis01 in forum Linear and Rotary Motion
    Last Post: 02-10-2017, 01:27 AM
  2. Timing Pulleys
    By rvoh1 in forum Momus Design CNC plans
    Last Post: 01-08-2016, 05:31 AM
  3. Looking for GT2 timing pulleys
    By salp in forum Want To Buy...Need help!
    Last Post: 11-27-2015, 05:28 AM
  4. Need help with timing pulleys
    By Ivano in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2013, 08:09 AM
  5. i want to cut timing pulleys , so help !!
    By max_imum2000 in forum MetalWork Discussion
    Last Post: 08-08-2008, 06:16 PM
