585,705 active members*
4,413 visitors online*
    May 2016
    30
    Actual power consumption 100w tube
    I figured co2 lasers are somewhat inefficient, but by how much ?
    What kind of wall power suckage goes on if i power 100w tube at 100% (yeah yeah inadvisable..) run included air extractor, water and air pump ? We're talking typical setup that chinese manufacturers send out in a crate. Not discussing chillers here.
    Granted, most will not use tube at anywhere near 100%, but its good to test the limits just to know.
    I'm in UK, that makes 240v supply.
    My machine is bobbling along in the crate on a ship somewhere, 6090 sized 100w EFR tubed. I'm pretty sure i do have capacity to run it but need to make sure wiring is up to snuff if it ever goes above 3kW (13A) with all the accessory bits connected.
    Re: Actual power consumption 100w tube
    My understanding is 65% is the max power with the stock Chinese laser tubes. Beyond that in continuous cuts & power drops significantly & also reduces the usable life of the tube. I have never run my 50 watt over 65%.
    Sent from my SM-G935F using Tapatalk
    Mar 2016
    94
    Quote Originally Posted by baronpork View Post
    13 amp is good we run our 130 w with chiller on 13 amp
    Dave
  1. Is this tube 80 or 100w?
    By pakt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2019, 08:03 AM
  2. 40 watt tube on a 100w Power supply
    By KenR60 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-11-2018, 04:46 PM
  3. RECI 100W tube with HY-T150 (150W Power Supply) : is it possible ?
    By medmouncef in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-25-2017, 11:29 PM
  4. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
  5. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
