586,009 active members*
4,762 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > SF Series machine depth not correct after replacing Stepper card
    Apr 2018
    8
    As the title reads, I replaced the stepper drive card on my SF Series machine, and now it will cut all the way through the 1/4" tabletop. Usually I have it cut about .030/.040" deep. How would I go about fixing this to get the correct depth back?
    Sep 2006
    118
    Re: SF Series machine depth not correct after replacing Stepper card
    Sounds like your step settings may be off. Does the driver(s) have stepping DIP switches on it? If the driver is identical to the one removed the DIP switches must match. Most stepper drivers have adjustable stepping. Full step, half step, 1/4 step, etc. Note: the Z stepper card more than likely will use a different step setting than your X and Y axis step drivers, as it is screw driven.
    Neal
  1. Replies: 0
    Last Post: 05-24-2015, 06:14 AM
  2. CAN'T GET DEPTH CORRECT
    By viper1753 in forum Mach Mill
    Last Post: 08-11-2014, 10:50 PM
  3. Replies: 2
    Last Post: 05-12-2014, 05:05 PM
  4. Replacing the MPC03 card
    By adrianhdezch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2010, 10:20 PM
  5. Z axis depth not correct
    By jtriggs in forum Mach Mill
    Last Post: 12-27-2006, 06:52 AM
