pls, when using igf, is it possible to avoid the M05, before a g-code sequence ?
please, when using igf, is it possible to avoid the M05 ( so to keep the spindle running ), before executing a g-code sequence ?
please check attached image : even if operations 3 & 4 are turning operations, spindle is stopped between them
i believe that M05 is triggered by default, because igf has no clue what's inside next g-code sequence; so far, i could not find a parameter to change this behaviour, and i wish to avoid *.min editing / kindly
