I have what is probably a simple question that I'm guessing someone here can answer. If this should be asked in a different subforum, let me know.
I have a Benchtop Pro 2424. It has currently a 3/4 MDF spoilboard mounted onto the standard aluminum table, and that spoilboard has a grid of threaded holes. This normally works great for what I do with the machine, but I have a project in which vacuum would be much more convenient. I was considering trying a simple removeable vacuum table, in the sealed MDF plenum and MDF bleeder board style. I can cover all of the unused area when cutting. I am out of space, money, and sound capacity, so I'm going to try using a Fein vacuum with it. I realize that's not ideal, but I'm going to do it anyway.
My question is: does the bleeder board need to be glued to the plenum? What I'd really like to do is NOT glue it to the plenum, so that I can bolt the plenum itself to the existing threaded spoilboard and still be able to remove the whole setup easily when I want to not use it. It seems like vacuum should hold the bleeder board in place, assuming the top is entirely covered either with the work piece or dams, but it also seems like a lot of people glue them on.
If it IS necessary to glue the bleeder onto the plenum, would it be a viable option to put access holes through the bleeder so I can get to the bolts in the plenum? Maybe as long as they're covered or sealed up when vac is on it's ok?
Anyone have any experience or suggestions about this?
dzsflw
