I'm currently running my 6040 laser cutter out of the cellar with the standard PC-fan type extraction in it. The smoke gets blown out of a window. However, I would like to stay on good terms with the neighbors, so I want to add a filter to the extraction piping. I've bought an inline fan with double the capacity of the current fan. This will be placed on the end of the extraction piping (less than 3 meters long) with a filter box in between.
Regarding the filter box: I find simple filter boxes with "cloth" filters rated G3. The info I've found about this filter class is:
G - Filters for coarse dust particles - Efficient for particles ? 10 ?m (EN 779)
Examples of separated particles material: Flower pollen, Pollen, Fog
Recommendation for application:
- Waste air of painting boxes and kitchens
- Protection against the pollution of air conditioning and compact instruments (e.g. window air conditioning, fans)
- Pre - filters for the filtration classes F7 and F8( it is necessary only for heavy polluted input air)
- Pre filters and circulation filters for public protection equipments
Since I'm not looking to re-circulate the air, but rather remove most of the smoke from the exhaust I was wondering if this might be sufficient. One more upside: replacement filters are pretty cheap and you can even have filters you can clean to re-use.
Or should I invest in a filter of a higher class (e.g. M5)?
- Niels
