585,994 active members*
4,675 visitors online*
    Oct 2010
    670
    Turret for the Slant Pro - Pros / Cons
    Looking for anyone who added a turret to their Slant Pro after they had been using just gang tooling. Basically, was it worth it? I keep going back and forth on should I add the ATC or not. Sure would be nice to have some standard tools loaded at all times. I watched Cliffs video on how the turret gets you close but you will still have to dial in the tools each run if you want accuracy. I'm okay with that, seems like it would be better than a full setup. I know I'll have to take the enclosure off but that's okay, I had been needing to take it off anyway to do a better job of caulking and sealing the damn colander.
    So.... Post up your thoughts. Right now I'm leaning towards adding the turret as the first of my 2019 upgrades plan.
    Awall
    The Body Armor Dude - Andrew
    Nov 2014
    17
    Re: Turret for the Slant Pro - Pros / Cons
    Wow, too bad nobody ever commented on this. Did you ever upgrade to the Turret?
  1. ViaCAD Pros & Cons
    By CNC_Kid in forum ViaCad / Shark
    Last Post: 02-21-2014, 09:14 PM
  2. Pros and Cons
    By SB2C-1 in forum Surfcam
    Last Post: 12-13-2010, 11:48 PM
  3. Pros and Cons of X4, CNC Jr...
    By timberwolf5480 in forum Benchtop Machines
    Last Post: 04-16-2009, 04:46 AM
  4. pros and cons
    By stirling in forum Stepper Motors / Drives
    Last Post: 08-28-2007, 03:40 PM
  5. What are the pros and cons of
    By cncadmin in forum CNC Machining Centers
    Last Post: 05-19-2003, 06:31 AM
