585,712 active members*
3,833 visitors online*
Results 1 to 7 of 7
    Oct 2018
    Question on Mach3
    Hello can anyone please tell me that I brought TB 6600 drivers , NEMA 34 stepper motor 35kg and a mach3 interface board. The Dro of mach3 is running but motors not. Please tell me is this problem in connections or something else. And please tell me how to do connections in between motors , drivers , and interface board. Thank you
    Sent from my era_4G using Tapatalk
    Dec 2014
    62
    Re: Question on Mach3
    there are many tutorials on youtube about the step for step setup with mach3. in my experience the best thing in the beginning is work through a tutorial. then your machine should work.
    michael
    Oct 2018
    Quote Originally Posted by neptunier View Post
    michael
    Hi can you prefer me some videos. I can't find the perfect solution for it. Thank u
    Nov 2013
    4358
    you'll get more response from the Machsuport Forum.
    Craig
    Nov 2013
    4358
    you'll get more help on the Mach forum.
    I use Mach4, and I could write a script for doing as you want in Lua. I imagine that you could do the same with Mach3 and Visual Basic
    but I hate Visual Basic....in fact that's the main reason I went to Mach4 in the first place.
    Craig
    Jan 2018
    1516
    Quote Originally Posted by Geeten View Post
    You likely sussed it by now but in these kind of situations for me it's something to do with Enable. Either wiring or pin selections.
    Sep 2005
    1740
    Your going to have to get wiring information, connections for the drivers and Mach3 board, same for steppers. Do some research and then draw out a diagram. What are you
    trying to build and do you hav Any Experience at all in CNC?
  1. Mach3 question
    By Jono888 in forum Mach Software (ArtSoft software)
    Last Post: 05-08-2017, 01:46 PM
  2. mach3 question
    By brinmac in forum Mach Software (ArtSoft software)
    Last Post: 04-13-2015, 07:17 PM
  3. mach3 question
    Last Post: 04-13-2015, 03:09 AM
  4. Mach3 Question
    By binfordw in forum Benchtop Machines
    Last Post: 12-14-2010, 10:09 PM
  5. mach3 question?
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 09-18-2009, 05:35 AM
