585,981 active members*
4,470 visitors online*
Results 1 to 6 of 6
    Mar 2019
    Help needed!!!
    I am a total newb with a mini lathe but I brought myself a new Conquest Super Lathe.
    I'm having trouble drilling any kind of metal.
    I can drill a small hole in steel and bronze with a center bit followed by a small drill bit, but when I use any drill bit over 10mm it just makes a high pitch squeel followed by the chuck stopping spinning and a grinding noise like the belt is slipping on the pulley, but no metal is being cut.
    All my drill bits are brand new.
    Does anyone on here have any idea as to what the problem could be???
    Thank you!
    Richard....
    Dec 2013
    5717
    Re: Help needed!!!
    Sounds like you are running out of power or have a loose belt. Maybe try feeding a bit slower or check the belt tension.
    Jim Dawson
    Sandy, Oregon, USA
    May 2016
    526
    Is the drill on centre line
    Mar 2019
    Re: Help needed!!!
    Thats what i thought. I have no idea what the tension should be on the belt but it looks and feels loose. the belt split in two in the first miniute of running the motor and it went back for repair. They replaced the broken belt with a more sturdy looking belt but I don't think they adjusted the tension.
    Do I need to adjust the motor position to do this and any guides on how tight the belt should be?
    - - - Updated - - -
    Quote Originally Posted by mbservice View Post
    I will check that.
    Dec 2013
    5717
    Re: Help needed!!!
    Quote Originally Posted by spiracy View Post
    I expect that you would have to move the motor, normally the mount or motor base is slotted to allow for adjustment. Tightness? Maybe 1/4 inch or so deflection with moderate finger pressure midway between the pulleys. This is a subjective measurement, but just get it pretty tight.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2006
    671
    Re: Help needed!!!
    Another thing that could be happening is you may just be running the spindle too fast. If there is a belt speed adjustment i would slow the spindle down. This will give you more torque which means you can feed a bit harder. Of course this won't help if your belt is loose so i'd start there anyways.
  1. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  2. Replies: 0
    Last Post: 01-27-2015, 02:31 PM
  3. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  4. Help With Project Needed - Guru Needed Please
    By cuetipper in forum DIY CNC Router Table Machines
    Last Post: 12-03-2012, 10:58 PM
  5. RFQ needed...parts needed ASAP
    By billet works in forum RFQ (Request for Quote)
    Last Post: 10-12-2011, 01:39 PM
