585,970 active members*
4,471 visitors online*
    May 2013
    62
    Issues with G03
    Hi All,
    I have a strange issue with the G03 command, sometimes it will not cut the circle, it moves to the location but does not do the cut.
    I was playing with some test code and found the following:
    Works:
    G00 x2.15 y10.4789
    G03 x2.15 y10.4789 i0.0 j0.65 f20.0
    Does not work:
    G00 x2.16 y10.4789
    G03 x2.16 y10.4789 i0.0 j0.65 f20.0
    Less than .15 works more than .16 on the x does not work. WTF?
    This is in Mach 3 connected to a Kflop/Kanalog system.
    Any thoughts?
    Cheers
    Chris
    May 2006
    4045
    Re: Issues with G03
    Hi Chris,
    Any error/status messages?
    What Version of Mach3?
    What Version of KMotion?
    Inch mode?
    If you split the full circle into two semi-circles does it work then?
    TK
    http://dynomotion.com
    May 2013
    62
    Re: Issues with G03
    Hi Tom,
    No error messages that I have seen, maybe I should have the kmotion console up to see. In Mach 3 it just goes to the start point sits there for a sec then moves on to the next point without performing the G03 motion.
    I have tried a few versions of Mach 3 with no difference (43.066, 42.020, 43.062). currently running the latest version 43.066.
    Latest version of KMotion
    Yes Inch mode
    I have not tried this but I will.
    Cheers
    Chris
  1. HELP WITH CNC ISSUES
    By chidyze in forum Chinese Machines
    Last Post: 04-18-2018, 02:48 PM
  2. Having issues with v23
    By RforEDM in forum BobCad-Cam
    Last Post: 01-14-2015, 05:40 PM
  3. V24 issues
    By Krustythebrown in forum BobCad-Cam
    Last Post: 02-12-2014, 03:47 PM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
