The SMOOTH ON command should only be issued at the start of a continuous unbroken chain of entities (on the same line as a G1). Then, a SMOOTH OFF command must be issued concurrently with the last entity in that chain.
No rapid movements should be incorporated within the chain of entities.
I have no idea how one could incorporate such smoothing gcodes within a standard CAM program, so I usually just hand edit the program, find the finishing pass, and insert the gcodes that call SMOOTH ON and SMOOTH OFF myself.
