585,758 active members*
4,594 visitors online*
Results 1 to 7 of 7
    Mar 2005
    816
    FANUC 18 Model C Build (FS18TC)
    FANUC A02B-0228-B503 Build
    Here I will document my FANUC 18T Model C Build
    Backplane:A20B-2001-0190/01A
    Chassis: A02B-0228-B503 (4 Place Backplane) dated 1997-09
    Power Supply: A16B-1212-0871
    FS16/18 Main CPU: A16B-3200-0210 (FS16/18CPU for 18)
    Module1: A20B-2902-0941 RAM; 4MB DRAM
    Module2: A20B-2902-0351 SRAM 768kB
    Module3: A20B-2902-0341 FLASH ROM 4MB
    Module4: A20B-2902-0981 SERIAL SPINDLE
    Module5: A20B-2902-0480 PMC (with I/O Link) RB5/RB6
    Module6: A20B-2902-0271 9" CRT CRTC MODULE
    Module7: A20B-2902-0070 Servo 5/6 Axis
    Module8: A20B-2902-0070 Servo 3/4 Axis
    Module9: A20B-2902-0070 Servo 1/2 Axis
    Option 1 Board: A16B-2200-0913 (communications function with remote buffer)
    Module1: A20B-2900-0361 (Communication Control) ; (Will display COMMUNICATION MOUNTED)
    Option 2 Board A16B-2203-0033 SubCPU for 18
    Module1: A20B-2902-0081 Flash ROM 4MB
    Module2: A20B-2902-0359 Additonal SRAM 768kB
    Module4: A20B-2901-0941 DRAM 4MB
    Module5: A20B-2901-0985 Serial Spindle
    Module5: A20B-2900-0271 H-Skip DI & Analog I/O HDI+Analog
    Module8: A20B-2902-0070 Servo 5/6 Axis
    Module9: A20B-2902-0070 Servo 5/6 Axis
    Servo Amplifier 1: A06B-6079-H206
    Servo Amplifier 2 A06B-6079-H206
    Spindle Amplifier
    Spindle Servo: A06B-0853-B200
    Servo X A02B-0148-B
    Servo Y A02B-0128-B
    Servo Z A02B-0148-B
    Servo A/B/C/U/V/W (Rotary 4th) A02B-0128-B
    I/O Unit B: A03B-0807
    Backplane: A03B-0807-C01A ABU10A 10 slot I/O Backplane
    I/O Interface: A03B-0807-C011 AIF01A
    (Modules listed L to R)
    A03B-0807-C052
    A03B-0807-C104
    A03B-0807-C106
    A03B-0807-C107
    A03B-0807-C150
    A03B-0807-C152
    A03B-0807-C154
    A03B-0807-C158
    A03B-0807-C161
    Machine Operator Panel
    CRT Panel: A02B-0120-C041/TAR
    A61L-0001-0093
    Re: FANUC 18 Model C Build (FS18TC)
    And your reason for posting this is????
    Mar 2005
    816
    So that anyone who wishes to build or retrofit their machine or control can add the proper parts. All available on eBay.
    Feb 2012
    126
    I haven't really dug into the yellow plastic box controls yet, but I have a couple so it is good information to have stored away for the future. May as well include the versions of software you are using to make it all work together. What are the differences in hardware between the 16 versions and the 18 versions. What does the 18 offer that the 16 lacks?
    Mar 2005
    816
    I have been trying to find FS16/18 Model C Main CPU and both option boards for less than $1,700 ea. Even just a bare CPU board without the cards.
    Anyone out there have parameters for any lathe with a FANUC 18T model C? I'd love a copy. Doesnt matter which lathe.
    Mar 2005
    816
    Here is a update to the I/O portion of the build, most of the modules you will need are Digital and 16 point
    I used one module per part number and this should be plenty for the 10 slot interface.
    A03B-0807-C052 ADA02A
    A03B-0807-C104 AID16D
    A03B-0807-C106 AID32F1
    A03B-0807-C107 AIA16G Analog Input
    A03B-0807-C152 AOD08D
    A03B-0807-C154 AOD16D
    A03B-0807-C155 AOD32C1
    A03B-0807-C158 AOA08E
    A03B-0807-C161 AOR16G
    Apr 2009
    1379
    I have the following:
    A16B-3200-0210 (all modules except sram) Main CPU 18
    A16B-3200-033 (no modules) OPTION 2
    A16B-3200-0054 (no modules) PMC-RC
    A16B-2200-0955 complete I/O card
    I probably have the missing modules if needed.
    Send an email [email protected] if you are interested.
  1. Fanuc model 3 model 6 ladder
    By ThienHa in forum Fanuc
    Last Post: 01-20-2024, 10:59 AM
  2. Replies: 8
    Last Post: 08-15-2022, 08:16 AM
  3. Model engine build Challenger V8
    By henken in forum I.C. Engines
    Last Post: 12-07-2013, 08:46 PM
  4. Lumenlabs V3/M3 micro good model for a DIY build?
    By Gonzodada in forum DIY CNC Router Table Machines
    Last Post: 09-22-2011, 12:14 AM
  5. A model build...
    By mdre83 in forum Uncategorised WoodWorking Machines
    Last Post: 03-16-2009, 10:07 PM
