I loaded the 2017 Screenset last week and copied all of the macros across etc. working well, tool setting etc all good and I think the VFD speed control was working as expected (in the 2017 screenset)....until 2 days ago...
I loaded UCCNC 2017 SS as normal, ran a test file and noticed that I couldn't change the Spindle speed from the last setting of 5000RPM. I can turn the spindle off and on ok with the M3 button and with an M3 command, but not set speed.
After checking all of the settings without a fix, I closed and reloaded my original config that I used as a base for the 2017 screenset and it the speed control of the spindle worked perfectly. So I checked all settings to make sure the 2017 SS matched and it does...
So I re-downloaded the HY Pluggin from Dan911 again and set up again on both screensets, original and 2017 and same result. it works in my original, but not the 2017 version.
I am really scratching my head on this one...
