585,987 active members*
4,372 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Manual chuck on Emco Compact 6P / 120P / 220P
    Apr 2008
    384
    Hello all,
    Specifically regarding the Compact 6P, although the answer's probably the same for the 120P / 220P - Can the pneumatics for the chuck / collet be easily removed so that a manual chuck can be fitted, allowing use of the through-spindle bore ? (Without removal / replacement of the whole headstock and spindle with the standard non-P unit.)
    Thanks.
    Apr 2008
    384
    Re: Manual chuck on Emco Compact 6P / 120P / 220P
    The similar threads have pointed me to this which pretty much answers my question, it looks like the pneumatics have just been unbolted from the spindle:
    https://www.cnczone.com/forums/showt...%20CNC%20lathe
  1. Emco compact 5 cnc turret & chuck
    By tenaja in forum EMCO Lathe
    Last Post: 01-20-2016, 12:36 AM
  2. ER 32 chuck for my EMCO compact 6 cnc
    By rot in forum EMCO Lathe
    Last Post: 10-26-2014, 02:50 PM
  3. Replies: 0
    Last Post: 11-22-2013, 07:49 PM
  4. Manual chuck for EMCO compact 6P CNC lathe
    Last Post: 07-31-2011, 12:33 PM
  5. Emco Compact 5 CNCLathe Manual.
    By sparkymike in forum EMCO Lathe
    Last Post: 02-07-2011, 10:13 AM
