586,005 active members*
5,260 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Robodrill Machine Frame DIY mill Build
Results 1 to 8 of 8
    Jan 2018
    7
    Hello to all,
    Want to share my story.
    it started with Weiss WMD25V mill converrion, after I wanted more power and working area, so I build large metal monster. this one was not rigid enought to process Steel and machining Speed was to slow.
    So I decide to buy Real machine frame:
    Jan 2014
    126
    Re: Robodrill Machine Frame DIY mill Build
    WOW! Where did you get the frame? It looks new.
    Apr 2005
    861
    Nice, that's a really good find.
    I like the Robodrills, very versatile. Interesting how small that Z ball screw looks compared to the size of the head.
    LongRat
    www.fulloption.co.uk
    Aug 2016
    132
    Quote Originally Posted by LongRat View Post
    I'm 99% certain that the frame is not from a Robodrill. As far as I'm aware, Fanuc has never used BK style bearing blocks, they've always been mounted in a casting that the motor bolts to. And the rails have never been Hiwin, always THK or NSK.
    Very interested to hear where it was bought, though.
    Jan 2018
    7
    Hello,
    Sorry For late reply.
    BK-BF blocks it is from me, Hiwin also my idea , Frame came with no linears and ballscrews. all other mountings my job.
    I am very begginer in this job and I am sure that Parts i chose for this frame is not perfect, but I will share all info:
    Linear motions:
    for X and Y axis - Hiwin HG series 25mm. (original comes with NSK).
    for Z axis - Hiwin RG series 30mm linear, this series of linear I have used first time and I can tell that it is much more rigid and curate.
    Ballscrews:
    China manucatured dual ball nut ballscerws, very cheap but looks like in future I will change it, No backlash but it is not accurate I need.
    CNC system - Mach3 Board.
    Axis electronics - Stepper motors and drivers:
    X and Y - 110HS28 - 28 N.m (3,965 Oz-In) 2 Phase NEMA 42 Stepper Motor; 1A phase current
    For Z - 110HS28 - 28 N.m (3,965 Oz-In) 2 Phase NEMA 42 Stepper Motor; 1A phase current
    Drivers - Leadshine DM2282
    Spindle motor - 3.5KW 3 phase motor 3000RPM controlled with inverter.
    Spindle - China ATC BT30 Spindel,
    Yes Frame is new. Unused.
    this is how machine looks like now:
    this is one of the first Part chained (B30 Tool holder):
    I have Some problems ad question, I will write down here later .
    Jan 2018
    7
    Nice build! How did you acquire the frame? I'm curious if it is possible to consider the same build concept.
    Jan 2018
    7
    Quote Originally Posted by fostereast View Post
    if enybody will need i Can help to get this frame, but project goes to 16k usd. Not sure it cheap build
  1. Second build - Baltic Birch Frame
    By Biggs427 in forum CNC Wood Router Project Log
    Last Post: 01-14-2023, 07:53 PM
  2. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  3. Is this a good frame and gantry to build on top of?
    By sac75578 in forum DIY CNC Router Table Machines
    Last Post: 03-04-2017, 09:10 AM
  4. CNC metal C frame build
    By Tristar500 in forum Uncategorised MetalWorking Machines
    Last Post: 11-24-2013, 12:51 AM
  5. Frame Build - Lead screw Q
    By viroy in forum DIY CNC Router Table Machines
    Last Post: 12-13-2009, 03:04 AM
