Hi Mark,
See the Modulo360.c example:
If your system has encoders the encoder would need to be adjusted also:
Code:
#include "KMotionDef.h"
#define CNTS_PER_DEG 1000.0
#define AXISA 4
double modf(double, double *); // returns integer part with more than 32-bit precision
double floor(double x) // truncate down toward -infinity
double y;
return (modf(x, &y) < 0 ? y - 1 : y);
main()
double dest = chan[AXISA].Dest;
double cnts = CNTS_PER_DEG * 360.0;
double delta = (floor(dest / cnts)) * cnts;
WaitNextTimeSlice(); // Avoid interrupts
DisableAxis(AXISA);
chan[AXISA].Position -= delta;
EnableAxisDest(AXISA, dest - delta);
